Question about Whirlpool AD35USS Dehumidifier
Water draining onto floor not collecting in bucket. What could cause this?
    President:
  • 2,080 Answers
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.ajmadison.com/cgi-bin/ajmadison/AD35USS.html
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.ajmadison.com/ajmadison/itemdocs/1188927.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Well, the first obvious thing to check is whether your collection bucket has a hole or a crack in it which is allowing the condensate to leak out onto the floor.
The other possibility is that you are missing your DRAIN CONNECTOR COVER which blocks up the drain hose connection on the side of the unit. This hose connection is used when you want to run the unit continuously with a drain hose attached and don't want to have to empty the bucket all the time. There shoud be a small screw in plug to cover this drain connector when not in use. See page 7 of the manual for detailed instructions and illustrations.
If your collection bucket is just overfilling and spilling onto the floor and the unit just keeps on running anyway, then you have a problem with the float level shut off switch which needs adjusting or replacement.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 24, 2011
Why does Frigidaire dehumidifier send water outside bucket?
Good Afternoon Jean,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Why does Frigidaire dehumidifier FAD704DWD send water outside unit?
Good Afternoon Friend,
-Best Regards-
WP
Jul 02, 2014 | Frigidaire a/c fad704dwd 70 pint...
When i take out the collection bucket there is a clear hose on the left side that goes up that is disconnected and leaks water on the floor not into the collection bucket
If you look at the gray plastic part at the top, there's this gray nub thing. Slide the tube onto that and your problem is solved.
Sep 20, 2011 | DeLonghi DE400P Dehumidifier
Does not shut off and overflows
In most cases this problem is caused by the water collection bucket not being installed properly. It may not have been pushed in far enough to allow the full switch to activate when needed. Be sure that each time you remove the bucket to empty it and then reinstall it, that the lift handle of the bucket is all the way in down position and that the bucket is fitting squarely into the holder from top to bottom.
Note: Your specific model has been discontinued by LG. However, some parts are still available if needed.
If you run your dehumidifier constantly and don't want to make a repair to it. You may want to consider using a drain hose, rather than the water collection bucket. This would require a floor drain close to the unit, though.
Hope this helped you to troubleshoot and solve the problem.
Jun 16, 2011 | LG LHD45EL Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Water not going into hose or bucket
where are u located and where aqre u using the unit
a dehumid wont work properly below 60 degrees
or 40 percent humidity
Oct 17, 2009 | Goldstar DH304 Dehumidifier
No water collecting, unit running
the collector base under the tubes just collects water and drips it through a hole into the water bucket. there must be a loose hose(if it has one) or the base collector or bucket has a crack, as they usually are plastic. also if the unit is sitting on a very uneven floor this will happen
Jul 24, 2009 | Goldstar DH3010B Dehumidifier
Unit runs but water collects on the floor
The drain hole within the unit is most likely plugged up with an accumulation of crud. (Common problem). Depending on the make/model, you may be able to access that drain hole by simply removing the collection bucket. If not, then unplug the unit and remove the housing to gain access to the internal drain.
Jun 19, 2009 | Goldstar DH304 Dehumidifier
Water collects where coils are at...
search for drain hole beneath coils probably plugged,mine was.
Aug 27, 2007 | Goldstar DH504EL Dehumidifier
Whirlpool AD35USS Dehumidifier Logo
378 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
