Question about Dell Computers & Internet
I bought a dell demision 3000and i worked the first time i turned it on and then after that it keeps say primary drive not found and strike f1 for retry boot up and f2 for setup utility and when i press f1 and just keeps repeating the same thing
    Scholar:
  • 142 Answers
Is this a new purchase? If it has a warranty call Dell. If not, then it sounds like either your hard drive data cable or power cable came loose - or the hard drive went bad...
Posted on May 24, 2011
My dell d2400 will not boot up, I get the primary drive 1 not found, strike f1 to continue, f2 to run the setup utility
when the operating systems was setup on your hard drive, the incorrect partition was set. this causes that screen to appear. more often people will choose that way so that you may have full advantage od a smaller hard drive. this will not affect the performance of the system in any way. the fact that you have to hit the f1 key on startup is just an inconvenience.
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Secondary drive 0 not found
Hi there.
Sounds like the boot order has been changed in the bios.
The secondary drive sounds like the CD drive as most laptops only come with 1 HDD installed.
Change the boot order to the primary drive by Pressing F1 during startup when the ThinkPad logo is displayed..
Once in the bios change the boot order, save and exit, the computer will restart and boot from the hard drive, when you get into windows check to make sure that the CD rom recognizes CD/DVD's.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | IBM ThinkPad T20 2647 Notebook
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Cannot boot my dell dimension 3000
Did you check inside and see if all the cables are attached?
Is the hard drive spinning, it may be bad.
Did this just happen?
Nov 14, 2007 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
Alun Cox
