Question about Hitachi Televison & Video
I have a Hitachi 50UX19K rear projection tv. It worked last night, then today I went to turn it on, the light came on for about 1 second and then clicked off. After that it will click, but nothing happens. Once I unplug the unit, it try to come on for the 1 second and click off again. I can see no burnt or obvious sign of problem. I have some back ground in electronics. Is there anything I can check with an Ohm meter? I recently installed a remote controlled outlet in line to save electricity. Is this what caused the problem?
  • Phil Saving
    Phil Saving May 24, 2011
    The information was helpful. I did discover a reset procedure
    for the surge protection didn't reset until I waited and then pluged
    in the unit and then it reset.
  • Hitachi Master
  • 19,396 Answers
Hi.
If the remote controlled outlet caused a power surge, this may have damaged the PSU.
As a matter of fact, if the TV shuts down completely after clicking instead of going to forced standby (protect mode), then the part damaged is either PSU or protection circuit.
The TV first test is done visually inspecting the PSU. See if you spot any bulged capacitor or blown component. If there is none the PSU must be tested. Read impedance in resistors, starting from the AC section (near power cord). In the AC section there should also be a Zener, in case test it using the diode tester function of the multimeter. Test power cord and soldering joints for continuity (read Ohms to see if they are open). If the AC section is OK, check if there is any voltage in the DC/DC section (you must have technical training to do safely the tests mentioned).In DC/DC section check 10 and 16V. If TV is not in standby, then there is no +5V. If all voltages come on and TV shuts down check the protection circuit. This is tested following instructions on service manual. As an example check the diagram at page 34 of the service manual for a similar model, available for free at the link below.
Hitachi Rear Projection
The manual for your specific model is available for purchase here:Hitachi 50ux19k Service Manual - Service Manuals, User manuals ...
Regards.
Ginko
Posted on May 24, 2011
Electric went off last night. tv turns on but no picture today, any ideas how to fix?
try to replace your regulator that is the common part when the the electricity goes out try to put a ups on your tv so it wont be forced when the electricity goes out.
Oct 12, 2010 | Hitachi 51F500 51" Rear Projection...
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
Hitachi 50ux19k model that will power on and powers right off.
Replace Both of your STK ICs that will fix this they are big black ICs will have part number on them STK392-110 use 180s Mats Electronics has them 1-800-628-1118
Mar 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
Today the TV just turned off by itself. I
Its your STK ICS STK 392-110s are Factory ICs use STK392-150s Call Mats 1-800-628-1118
Dec 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
RED BLINKING LIGHT ON HITACHI TV CANNOT TURN ON
Check the resisters, that could be the burnt small, also you may need to replace the ICs
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Projection TV turns off for a few seconds
Good Day, boattech1;
To my understanding the Model 53UDX10B is a rear projection, that uses no fans. I think maybe your LAMP may be getting weak.
Good Luck, big IRISH.
Jul 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Troubleshooting
This has happened a couple of times--no big deal, it just seems to need "re-booting". Try holding 'home' button and 'sleep' button at the same time for 15-30 seconds. That should do it.
Aug 31, 2007 | Hitachi 46BX01B 46" Rear Projection...
Tv went off by itself
When you turn the tv on all the voltages come up for a second but the power supply is sensin a problem and it kills the high volatge and other voltages.One of the voltages the supply sends has a short.The tv needs to be service because components need to be checked and then replaced. Be safe and Seek the help of a technician to diagnose the problem.
Oct 01, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
146 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
