Question about Kitchen Ranges
I bought the Brinkmann 5-Burner Grill Model 810-9520 a little under a year ago and recently have been having problems with the flame. The grill will lite with a strong flame if just one burner is on, but once I turn on the other burners, the flame becomes basically invisible. I have removed the grates and tried to clean out the burners but there is no change. I just recently replaced the propane tank so I know that isnt the problem. Please help me!
  • 10,865 Answers
Hello megan. actually the propane tank is causing this problem. the newer propane tanks have a safety feature built into them to prevent fires and explosions. that is a good thing. what is not so good is that the tanks are now a wee bit tempermental. this is what you now need to do. turn off the tank and unscrew the hose. let the hose sit unattached to the tank for 5 minutes then hook it back up and very s-l-o-w-l-y turn on the gas. That should solve the problem. if it doesn't repeat the procedure. joe
Posted on May 24, 2011
I have a Brinkman Gas Grill Elite dual Sear 5 Burner.
Check the reg sounds like its not giving full rate
Oct 08, 2017 | Brinkmann Grilling
I have a brinkmann 3 burner grill, the middle burner flames, but the outside ones do not, i just bought it today. How do I light the outside burners?
I am not sure, but I think the Brinkman uses the ignitor to light one burner and the other burners light after the first one allowing the flame to "crossover".
Gary
Sep 18, 2011 | Brinkmann 810-8410-S Stainless Steel...
I have a brinkmann 4 burner. The cross over at the back of the burners has it's own flame. The back of the grill, even at the lowest setting is still very hot. Flames come up between the plates. On...
Sounds like a gas regulator problem. But, somewhat unusual, as most people complain of low flames. In any event, you will need to replace the Hose/Regulator Assembly. They run about $30.00 and can be found at any hardware store or home center, that sell gas grills and accessories.
As a safety measure, after turning off the gas tank, check each burner for blowout or rust through..
I hope this helped you and thanks for choosing FixYa.
Jul 31, 2011 | Brinkmann 810-8530-S Stainless Steel...
Bought the Brinkmann 5 Burner Grill Model 810-2545-W grill from WalMart last night and it did not come with the owners manual. No manual can be found on the Brinkmann website for this model.
Wendy, the easiest and fastest thing to do, if the Owners Manual for your model Brinkmann grill is not listed, is to call their Customer Support number 800-468-5252. And they will either send you one or email it to you with an attachment in pdf format, that you can download and print..
Hope this helped you. Please let me know and Happy Grilling!!
May 06, 2011 | Grilling
Need to find replacement burner and ignition for Gas Grill King Deluxe Model 810-3200G. This grill is about 11 yrs. old but still in good condition, just would like to replace some of the...
Susan, Clagrills stock more Brinkmann parts than most. The link below will take you to them. If you do not find your exact model number (your grill is 10 years old), Look at the pictures/drawings and their dimensions) and you will probably find one that will interchange with yours.
Good luck. www.clagrills.com/grillparts/brinkmann/brinkmann-grill-parts-home.htm
Apr 07, 2011 | Brinkmann Grill King Deluxe 810 3200-0
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
Low flame
this is a problem with the regulator. It is not allowing enough pressure to maintain the burners when all are lit on hi. You can get these regulators at most major retailers or directly from th emanufacturer.
Hope this helps you out.
Jun 15, 2008 | Brinkmann 810-2300-B Grill
Kitchen Ranges Logo
162 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
