Put in new batterys now the remote will not turntv or any other functions???
  • 51 Answers
A lot of remotes have different modes, "tv, cable, vcr." its possible that you accidently pressed the button for a different mode. Try pressing the "TV" button, then powering it on.
Posted on May 24, 2011
My tv remote .It just stopped working.I put new batteries .Why.Two adults in home .Why would a remote stop functioning!!!???
Why is my remote not working?
To determine which of these conditions is causing your problem, follow these steps: 1) Open the battery compartment on the back of the remote and remove both batteries. 2) Press and hold any button on the remote for 20 Seconds. 3) Release the button and reinsert the batteries properly.
How can I solve if the remote control is not working? - Samsung
www.samsung.com/sa_en/support/skp/faq/239888 Search for: Why is my remote not working?
Why would remote stop functioning Google Search
Dec 09, 2016 | Televison & Video
Remote works with on and off and volume but stopped all other functions.
1 Remove the batteries form the remote and blow hot air by hair drier about 5 seconds . replace the older/ used batteries with new one of same kind. Does it solve your problem ?
2. Remove the batteries and unscrew the remote and then open the case of remote , clean the PCB's key pad area with soft and dry cloth , put small amount of carbon ink (purchase from electronics parts shop- cost $0.5 approx) on key pad's back side round dots, let it be dry for 30-45 min , assemble the remote and fit batteries and enjoy.
May 27, 2016 | Universal Remote Universal Genesis Remote...
Mitsubishi tv remote will not turn tv on. put in new batteries already . only the red light on the tv button turns on.
You should reprogram your remote. Start with the tv on. You have got to find a code that will operate all of the functions you want it to. In others some code will only turn on the tv. Some codes will work with volume and the channels. Once you find a code that works you should be able to operate the tv with the remote. It sounds like to me when you put new batteries you erased the function of your mitsbishi remote. So once the tv turns off you have found your code.. but make sure before you save it you write down on something; and, it works all of the functions that you want it to. I hope that this helps a ton...
Jun 29, 2014 | Mitsubishi New Original 290P137C10 Remote...
Remote control not working
My remote does not work. I have put in new batteries but it does not work. Is there any way I can get a new one?
Jan 29, 2012 | Dell W4201C 42 in. Plasma HDTV
Remote with new battery seems to have all functions except the lock door function. The armrest control has normal function and will lock and unlock. The remote will then unlock but will not lock. This is a...
possible bad button on key fob.unlock button good lock button bad .get a new clicker you can program it yourself ....put key in ignition turn back and forth 10 times while holding the unlock button on remote.that should work
Aug 05, 2011 | 1998 Ford Explorer
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
Have a protron pltc-26 and the remote qiut working put in fresh batteries but will not turn on tv
The remote control is dead or the remote CPU chip that control all functions is dying and only some of functions buttons will work,some wouldn't anymore or the rubber insulater between the rubber buttons and the remote circuitry board are worn out and make no more contact.Can u take the remote aparts?Yes.Check all the rubber butttons insulater see if they're still good.Tries clean the remote PC circutries board with some rubbing alchahol also the battery - + connections too.Wait like about 20 mins for the rubbing alchahol to completely dries.Putting it back together again an putting in new batteries,the remote control might work again.If not have same result.Try website like Remotes.com to buy an original or very close compatible remote for a replacement.
Mar 23, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Streamium Remote control
Use new batteries for the remote.
May 31, 2008 | Audio Players & Recorders
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
