Question about Ryobi Cultivator
My cultivator started then it stopped. the sparkplug is new and it trys to start but want turn over
My 1998 oldsmobile will crank over but wont start it fires sometimes n trys to start but after that just wont start i have good fuel pressure n i replaced the sparkplugs the fuel reculator and the...
I would ask you to have your computer scanned for codes, this would tell you what is wrong, but possibly this may not be possible for you to do. Your description leads me to believe that your problem is a bad crankshaft sensor. GOOD LUCK FRIEND.
Feb 21, 2015 | Oldsmobile Cars & Trucks
Mantis tiller
is the kill switch off does it fire? have spark? start with the basics .air , fuel, and spark. hope this helps
Jul 06, 2014 | Garden
My yardworks snowblower engine not running
need more information, several reasons why an engine won't run
Nov 24, 2013 | Tecumseh Snowblower Snow Blower Starter...
Engine surges
sounds like a carb problem if new bring it back to the store
May 05, 2012 | Husqvarna DRT900 960930011 17 Rear Tine...
When installing clutch drum, it turns with the drive shaft
Hello , well you again, on some of the small tillers the tines will engage because that is the way they are made to do on start up,it is not a clutch issue,ad far as i know there is no way to disable this,it is a pain but this is the way it is,,hope this helps,
Jan 30, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Mantis will not start - has good fuel and new sparkplug
Check spark plug gap and functionality of throttle. I all is OK it could be flooded. If flooded. Remove spark plug and pull cord a helf a dozen time to clear it out. Replace plug with correct gap and start her up! Gap is .035-040 inches. If you don't have a guage, 40 thou is about 1/6".
May 21, 2010 | Mantis 2-Cycle Tiller
Cultvator is not starting as we pull start
I take it this is the first cranking this season. The most probable cause is stale fuel. Never ever store fuel in a small engine over the winter. Now, the bad fuel has most probably fouled the sparkplug, so you need both fresh fuel AND a NEW sparkplug.
Your carb is going to be gummed up, but if you'll get the high priced fuel with the "cleaners" (like Chevron with Techron) it may save you the trouble of disassembling the carb.
Mar 21, 2009 | Craftsman Garden
Engine not sparking
Start with a new sparkplug.
Mar 20, 2009 | Garden
Ryobi Cultivator Logo
21 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
