Question about Samsung Microwave Ovens
My smh9207st has no power - Samsung Microwave Ovens
How to reset an error code of SE on a samsung microwave model SMH9207ST
May 24, 2017 - SMH9207ST
There's no reset for it, but you can find the two solutions on my page here: http://www.microwavecontrol.com/samsung_se_error.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Apr 19, 2017 | Samsung Microwave Ovens
What does se mean on Samsung over the range microwave model #smh9207st
The SE error code means a key has been depressed for more than 10 seconds. Press the "Clear" button, does it reset and work normally? If not, try completely cycling power to it. If that doesn't work you will probably need to replace the touch pad assembly.
Aug 02, 2016 | Samsung Microwave Ovens
No power to unit replaced thermostat , door switches, diode on capacitor but not the two fuses continuity goes to 0
There are 2 thermostats or "thermal fuses" in it that would cause no power. One is on the magnetron, the other is above the microwave cavity near the middle. Have you checked/replaced both? You should have 120 volts between the white wire on the main relay on the circuit board & the black wire in the smaller connector on the board. If you do, bad board, if not, something before the board (fuses, thermostats, noise filter board, etc). Door switches, diode, capacitor would not cause no power to unit.
Jun 03, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Here is the product# SMH9207ST?
Check here for warranty info:
Warranty Information Samsung UK
If you are outside the warranty period you may find repair instructions online if you type the nature of the problem into Google, or give more specifics on the actual problem, like no heat, or no power etc. maybe we could help more, with pointing you to replacement parts etc :)
Jul 14, 2014 | Samsung Microwave Ovens
Samsung microwave oven model smh9207st shows 5e
Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
Jan 21, 2012 | Samsung Microwave Ovens
Samsung Microwave SMH9207ST lost power after cooking a meal, the power outlet works fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Apr 18, 2011 | Microwave Ovens
Microwave Ovens Logo
810 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
