Question about Garden
Lawn mower shuts off after approx. 5-10 seconds. Oil and gas are fine and spark plus is fine.
    President:
  • 1,545 Answers
Remove and clean the brass bolt that holds the bowl on the carburetor. It is the main jet of the carburetor. Use NO metal objects to clean it up. It has small holes in the bottom and along the smooth unthreaded part near it's top. Make sure it is clean and shiny. Carb/Choke Cleaner aerosol spray will clean it up pretty good.
Posted on May 24, 2011
What is wrong with my push mower?
Sounds like something relating to the engine is overheating and the heat sensor switches off the machine.
Jun 18, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Lawn mower stopping by itself
CHECK THE FUEL FOR CONTAMINATES OR OLD GAS
EMPTY COMPLETELY OUT AND PUT IN NEW GAS!
ALSO CHANGE SPARK PLUG!
IF YOUR LOW ON OIL, IT MIGHT AUTOMATICALLY SHUT OFF ALSO!!
Jun 15, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
I have a hrb216tda lawn mower that runs fine for 2 to 3 min. then stops like it is out of gas. i put on a new carb and does the same thing
Make sure your shut off valve is on positon not part way off,check for a screen plugged up in fuel tank or inline fuel filter, check for bad spark plug engine oil top up maybe saftety sensor when oil is low if you remove the fuel line from carb does gas flow straight out no problem?
Joe
Sep 11, 2012 | RTO Garden
Craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
755 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
