I make 17.26 hour and got a 5% raise, how much will i now make an hour
  • 300 Answers
I suppose this is a skill testing question. I wonder what the prize is ...
There are 2 ways of figuring this out.
1.
$17.26 x 5 / 100 = $0.86 (the amount of your raise, rounded to the nearest penny)
Now add $17.26 + $0.86 = $18.12 (Your new hourly rate)
2. $17.26 equals 100% which is your present rate, right?
If you get a 5% increase, you will be making 105% of your present rate.
All you need to do now is multiply $17.26 by 105 and divide it by 100
Posted on May 25, 2011
The blade on my new skil 3310 won't raise. It came preassembled & has never been used, but the elevation wheel feels locked. I can adjust the angle, but turning the knob doesn't raise/lower blade.
Just as a question and I am not being smart you know that the wheel to raise the blade work counter clockwise.
The other thing you need to check is in your manual here is the part how to adjust the blade for raisin/lowering.
After five hours of operation, the blade elevation/tilting mechanism should be checked for looseness, binding, or other abnormalities. Disconnect the saw from the power source, turn the saw upside down and pull up and down on the motor unit. Observe any movement in the motor mounting mechanism. Looseness or play in the blade raising screw 1 should be adjusted as follows (Fig. 55): 1. Loosen nut 2. 2. Adjust the nut 3 until it is finger-tight against the bracket 4, then back off the nut 3 1/6 turn. 3. Tighten nut 2. The maximum allowable play of the screw rod 1 is 5/32" (4 m). Place a small amount of dry lubricant (such as graphite or silicon) on the screw rod 1 at the thrust washer 5. Do not oil the threads of screw rod 1. The screw rod 1 must be kept clean and free of sawdust, gum, pitch, and other contaminant's for smooth operation. NOTE: If excessive looseness is observed in any other part of the blade elevation mechanism or tilting mechanism, take the complete unit to an authorized service center.
Oct 21, 2015 | Skil Saws
The temperature button is 1 to 5 which is the higher please
You first need to explain if those numbers are for the frig or freezer.
Let's say this is for the frig area, normally I would think 5 would be higher, but as a test, put a thermometer in the unit, set-it on 1, wait 24 hours, and look at the reading. If it is too cold then you know that you need to raise the numbers, same if you start at 5, and then need to go down to a lower number.
Mar 25, 2015 | Refrigerators
Is it easyer to remove a 3.8 buick park avenue engine from the top or dropping it from the bpttom.
If you have a lift, to raise the entire car in the air. Out the bottom. I can drop them in 1 and 1/2 hours. Back in and running in 5 hours. Don't have a lift. Out the top. Takes longer , but much safer. By the time you mess around with jacks to get the vehicle high enough, you would have already had it out the top.
Feb 26, 2015 | Buick Cars & Trucks
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
How to set the clock on a 2004 saturn vue
1. Turn on car
2. Push "clock" button
3. Wait until HR (hour) flashes
4. Look at the "tunes" button at the top right
5. Turn the "tunes" knob (yes, it turns!) left to lower the time or right to raise the time.
Repeat for the minutes
Good Luck!
Mar 15, 2011 | 2004 Saturn VUE
I have sc564 trouble with my ricoh aficio 1018. I called ricoh suport, someone should have passed thusday, we are friday and nobody!! I call again and we talled me "peraps on moday,..." I've...
look my friend this problem belong to thermistors are corrupted change it and it will work correctly there are many ways to solve this problem temporally but it revealed again 1 hour 6 hour and raise again thus change it byy
Dec 03, 2010 | Ricoh Aficio 1035 Copier
What are the uses of high raise of the engine (RPM)?
If the engine is cold it will race until warm. If the battery voltage is low the ECU will use a high speed to charge the battery.
Oct 14, 2017 | 1998 Toyota Avalon
Rudd furnace molel robd-150rbja worked good for 5 years now takes 24 hours to raise house temperature from 60 to 70 degrees burner fires properly then fan starts properly after about 5 mineuts of bott...
Get it looked at quick, before your exchangers crack, because the furnace not cooling them down after operation will lead to failure, and the replacement is not cheap, close to the cost of a new unit.
Dec 06, 2008 | Carrier 38CKC042 Air Conditioner
How do I solve radical expression and equations using the TI89?
1. square of 12
2. cube root of 48 a raise to 5 y raise to 6
3. square root of 128 y raise to 5
4. 6th root of 9 y raise to 2
5. cube root of 24 y raise to 5
6. 10th root of 32 x raise to 5
7. 15th root of 64 x raise to 9
8. 4th root of 10000
9. cube root of 192 p raise to 5
10. cube root of 256 y raise to 12
Jul 04, 2008 | Texas Instruments TI-89 Calculator
Kenmore Side-by-side refrigerator
try unplugging it for 5 min and plug back in?
Jun 29, 2007 | Kenmore 57029 Side by Side Refrigerator
47 people viewed this question
jasbo
jasbo
