Question about Maytag Neptune MDG5500AW Gas Dryer
How to install new baffles - Maytag Neptune MDG5500AW Gas Dryer
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please view this video for drum baffles replacement:
Please get back to me if you have any other questions.
Kevin
Posted on May 24, 2011
Napoleon NZ26 woodburning fireplace smoking back.
Get someone to come and do this correctly. You have a possible carbon monoxide poisoning hazard!!
Nov 18, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Had new fuel pump installed in 2000 ford contour, now the gas gage doesn't work. Could it have anything to do with the way the fuel pump was installed?
Yes, chances are the float is caught on one of the baffles inside the tank, or the float could have came off inside the tank. Most likely the float is caught on the baffle.
Feb 18, 2011 | 2000 Ford Contour
Washer door leaks
The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western Appliance Repair
Washer Repair
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does the kia sportage need a cork gasket installed with a new oil pan?
No, the baffle plate is the gasket...if it's not in bad shape put some red Permatex around the block, install the baffle,and oil strainer, then apply the permatex around the oil pan and install.
Jul 12, 2010 | 1999 Kia Sportage
One of the baffles broke off. I need to know how
Take the top of of the machine and rotate it until the baffle is at the top.  They usually have clips that hold the lid down, or screws under the head.  If the head is hinged and flips over the back the screws are under the head.  If not fine the clips, get a ling flathead and push it into the clips while prying up.  There are also two screws under the lint trap if it is on top.
Dec 04, 2009 | Dryers
Bad sound
Check speaker cable connected at the back panel sometimes cut or opened wire cause a baffled sound... Or try to buy a new sound card and install it to your pc.
Jun 22, 2009 | EliteGroup P4M800-M7 Motherboard
Baffles in washer
the new baffles arefairly easy to install, they go over the hole and then pull foward to lock into place.. the new bsaffle should also come with a screw to "lock" it, in place. in order to securethis screw you need to remove the top cover of the unit,(3 screws across theback) after removing the top youll see a black hose going directly into thetop of the tub prbably an inch or so . gently pull that hose out from thetub. It simply locks itself inplace.. after removing you can spin the inner drum around till thenew baffle is directly under the "hole" where you can now see a small hole inth eunderside of baffle to secure.. just remember to resecure that hose or youll have a flood on your hands
Mar 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Replacement baffle installation
its a little tricky but can be done. Can you remove the top panel of your washer?? 3 screws along the back lip and the entire top will slide back and off. theres a little black hose leading from the soap dispensor to the top of the outer tub assy. its only pushed into the tub and is real flexible, pull it out .you see through the maybe 2inch hole and see he inner basket. as you rotate the basket from inside with your hand the inner baffle(s) will line up to the hole and depending on date of manufacture. they might have put a small stainless screws in from behind to hold baffle in place,ifso remve the screws and the baffle (although a little tricky should slide toward the rear of machine to remove, and pull toward the front to reinstall
Mar 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
