Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater brush stopped moving - Dyson DC07 Bagless Upright Cyclonic Vacuum
    Master:
  • 956 Answers
First. Looking from the rear of the hoover forward, right side on main unit there is a large knob with signs, turn clockwise or anti clockwise.
If there is still no motion, check drive band is intact.
You can have a service man call from dyson £60.00 or there abouts, I believe this service includes all parts and labour.
Posted on May 24, 2011
Power spen brushes move very slow or stop
Not sure if you are speaking of a vacuum or steam cleaner or ?
If it is a vacuum, sounds like the beater brush is freezing up. Follow the directions to replace the drive belt. When you get the beater brush off the unit, clean it as best you can. Add a bit of WD40 between the ends of the beater brush and the hard rubber pieces that hold it in place. Before reassembling, turn the brush while holding the pieces one at a time to be sure the beater brush turns freely. When you reassemble, be sure the belt is properly installed.
If you find this solution to be helpful, I would appreciate an appropriate Thumbs Up rating from you.
Be well, Paul
Oct 06, 2010 | Vacuums
The motor is spinning and spinning the beater motor but the beater bar wont spin
Check to see if the drive belt to the beater is broken. Also, remove the beater brush and clean as best you can. Add some WD40 at both ends of the brush where the hard rubber/plastic pieces are that hold it in the unit. Spin the beater by hand to make sure it moves freely.
Oct 04, 2010 | Vacuums
Our vaccum cleaner does not clean up.
If the floor unit is not picking up, check for a broken belt for the beater brush or for a frozen beater brush. Might be a good idea to remove the beater brush and clean it of any debris and squirt some WD40 on the two end pieces that hold the beater brush to the vacuum itself. Turn the brush by hand to be sure it is free and reassemble. Make sure the belt is properly attached so it moves the brush in the correct direction.
If you find this to be helpful, I would appreciate you providing me with a thumbs up rating. Thank you. Paul
Oct 03, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
I have no suction from the bottom
If there are no obvious air leaks, check to see that the belt that turns the beater brush is not broken and that the beater brush has not frozen up. Remove the beater brush and clean it, spraying a bit of WD40 at each end by the hard rubber pieces that hold it in place. Turn the beater brush by hand to be sure it moves freely around the rubber pieces. When you reassemble, make sure the belt is properly installed.
Oct 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
I have a bissell easy vac and the metal part that spins the rubberband and brush keeps overheating and burning all the belts I replace. What should I do?
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 13, 2010 | Vacuums
My bissell helix cleanview vacuums brush doesn't spin
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Vacuum turns on but the brush is not rotating
Most likely a problem with the drive belt or the beater brush. Either the drive belt is broken or the beater brush is frozen due to debris. If you can not turn the beater brush by hand, it should be removed and cleaned well. The ends of the beater brush that hold it into the vacuum should be lubricated with some WD40 and moved by hand until they are free. Once the turn freely, replace the beater brush. If the drive belt is broken or missing, it needs to be replaced.
Sep 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
26 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
