Question about Dishwashers
Hi, I have a UK Neff S5444X1GB/08 fully integrated dishwasher which is having some problems with not finishing cycles. I was hoping to run the test cycle program but can only find US references to this and so am not sure which buttons to press to start the test cycle nor exactly how to interpret the outcome . My machine has 4 setting buttons: a 65 degrees, a 50 degrees, a 35 degrees and a rinse. Would you please be able to indicate which buttons run the cycle and what the various possible outcomes represent or indication which US model this is equivalent to so I can hopefully use the US instructions I found.
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
  • 98 Answers
SOURCE: Bosch built in dishwasher shu4302uc
There is a recall on the control board of many of these models. I have written a guide to help. It is here. Look for the phone number near the top.
Posted on Jul 19, 2009
  • 7 Answers
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Posted on Jul 29, 2009
SOURCE: Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Posted on Apr 06, 2010
I have an error code 08
Good Morning Friend,
I understand you are receiving an error code 08 on your Electrolux dishwasher, model# EWDW6505GS, and want to know how to correct it. Error 08 could possibly be that the control board has verified a switch on the user interface board being bad or shorted. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux EWDW6505GS Fully Integrated...
Dishwasher door will not close properly
usually d/w doors are fine for long time.
1. check if anything blocks it to close securely e.g. the cutlery basket or the dish racks not fully sliding in or may be off track/chanel.
2. try running a cycle empty and see if it closes after doing #1.
Jul 25, 2013 | Neff S51M53X0 24 in. Built-in Dishwasher
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher will not turn on, power check done, please help
this looks like a power supply problem if you are sure you are getting power right up to appliance it can only be a electronic failure pcb open circuit etc anything else and the lights would still illuminate.
Jul 25, 2009 | Neff 24 in. S5444X1GB Built-in Dishwasher
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
