Question about Hitachi Televison & Video
I have replaced the lamp in my 50VS69A. The oicture now has a blue verticle stripe along the pictures left side. How can this be adjusted to remove the stripe?
  • 2 more comments
  • jstier806 May 25, 2011
    I don't own nor do I have access to a dvd or dvd player. What may I try instead?
    same problem. I neither own a recorder nor do I have access torecorded media.
    I built military hardware in the 80's but have forgotten most of everything I once knew. Do I look for a local Hitachi repairman?
    I built military hardware back in the 60's. Too long ago for any help today. I guess it is time to call a local reairman?
  • 517 Answers
Good day!
actually that problem is not on the settings.
Please try to play a dvd movie or recorded shows to determined if your problem is on the TV itself or on the cable/aerial connections.
If the problem persist just add a comment.
Thank you for using FixYa!
Posted on May 24, 2011
  • 1 more comment
  • Rossiel Gomez May 25, 2011
    Try to play any recorded TV shows.
    so the problem is on the TV not in the cable/aerial connections.
    actually that problem is not on the adjustment it could be the failing parts inside of your TV.
    Did you have electronic background?
    OK sir if you don't have a electronic background or you forgot it.
    I suggest to call a hitachi repairman for immediate repair and troubleshooting.
    Because that problem is not for D.I.Y and not advisable for non-pro because it cause major trouble.
    Thank you and I hope this information will be helpful
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
I have a 1991 Ranger. I have replaced both my headlight assys. I've been able to adjust the passenger side light, but the driver's side won't move (vertical adjustment) will I have to tear it all apart...
The head lamp has two spings one to go verticle and the other to go horizontal,this is for each one,the driver look either to the right or left and youll see the spring
Apr 27, 2011 | Ford Ranger Cars & Trucks
Large verticle stripe on the left hand side of a 40 inch Samsung LCD TV. One can still see the picture & hear the sound on the rest of the tv. Stripe changes color periodically-goes from a solid to a...
you need to find the broken contacts on the offending matrix controllr and resolder it. Not for the faint of heart if your soldering skills aren't good!
Mar 08, 2011 | Televison & Video
My Viewsonic PJ860 projector (aka Hitachi CP-S860W) has developed a condition in which there is a yellow vertical stripe down the right edge of the screen and a blue vertical stripe down the left side of...
It does sound like this is an alignment problem of the blue LCD or a problem on the main board controlling it. I am not sure if this is a field adjustable unit. A call to the authorized service center should provide that answer.
Aug 11, 2010 | Hitachi CP860960LAMP Projector Lamp for...
I have a '03 model Samsung HLN5065W TV that after approx 1 hour, part of the images start turning white. If I shut it off, for only 1-2 minutes, the picture is good for another 15-20 minutes.Occasionally,...
Look on your Power supply board ,it will be on left hand side,Bad Capacitors 330uf 10v 220uf 10v 1000uf 16v if you see any that are swollen,or Puffed up on Top they are Bad replace them and order you another Lamp, I got Mine on Ebay for $85.00 Look under Electronics
Encompass Parts Distribution will have part number on their website just type in your model number and it will list Parts and Prices 1-800-638-3328
Apr 24, 2010 | Samsung HLN5065W 50" Rear Projection...
Green verticle line on right side of image
Your color convergence is out of adjustment. You can adjust yourself with a service manual telling you how, or take it to service shop and pay about $400.
Jan 17, 2010 | Sanyo PLV 60HT Multimedia Projector
Sony Grand Wega KDF-50E2000 with a red stripe on top of Picture
There are some adjustments that can be made to align the picture. This might correct your problem. They should only be made by trained serv tech. If that won't fix it then replace the light engine. There are 2 different ones for this model. They are serial number sensitive.
Oct 30, 2009 | Televison & Video
My hitachi 50VS69A tv shows the picture green.
A green image is usually due to a lack of red or especially blue. the problem is becoming all too common with hitachi lcd projection sets. what happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far gone except to replace the light engine-at acost that makes it not worth repair. if the damage is minimal than to reduce further damage the air filter should be replaced. Light engine needsto be removed in order to replace the air filter.
Sep 04, 2009 | Hitachi 50VS69 50" Projection HDTV
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Feb 04, 2009 | IBM ThinkPad T21 Notebook
Televison & Video Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
