Hello i cannot turn on my WI-fi adapter on Asus A2500H can u help me? when i try to install Wi-fi driver and run it it's told than cannot find the adapter
    Problem Solver:
  • 10 Answers
Wrong driver, get driver from OEM web site.
Posted on May 24, 2011
Installing wi-fi drivers for asus z87 motherboard
If the device has no Wi-fi device activated , it will not run a driver install
Mar 01, 2014 | ASUS Z87-DELUXE LGA1150/ Intel Z87/ DDR3/...
My laptop shows an erroe message that says that the wi-fi adapter is not installed
If you have the installer CD, then reinstall the motherboard's chipset. If you don't, go to the manufacturer's website then download and then reinstall the drivers you need for your wi-fi adapter.
Aug 26, 2011 | Computers & Internet
Format netbook and use windows7 ultimate.after installing my wi-fi doesnt work anymore...
You need to install the wireless network driver. Make sure that you are going to install a Windows 7 compatible driver. You need to indicate the type of wireless network card that you have in your computer.
Another thing that you need to make sure of is that the wireless switch on your portable is turned on. Usually there is a switch in the side of the portable or for other portable systems, you will need to use the Fn+F3 key to enable the wireless.
Jul 07, 2011 | Computers & Internet
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
Cannot turn on wireless lan with fn+f2 keys
1. first turn on the "wi-fi/wireless" switch on ur laptop manually.
2. now use the key combination for wi-fi/wireless
3. if it still not working, reinstall the wi-fi/wireless driver again, and restart ur system
Jan 01, 2010 | ASUS F6A-X2 PC Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
Aug 26, 2009 | Everex StepNote NC1502 Notebook
Asus 802.11g wi-fi only detects network when connect a cable to the external antenna. what should i do?
It seems that the signal reaching your modem is weak or it getting blocked by some electrical equipment, try relocating the antenna. But first try it on another PC at a different location to confirm that wi-fi is working properly..............sodeep
May 08, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Wireless no longer works
1st Solution:
Check if the wi-fi card is properly installed under Device Manager. Go to Start then look for Control Panel on the right pane. Under Control Panel look for System and Maintenance and then click on Device Manager. Now under Device Manager look for Network Adapters and collapse or click the arrow next to it. Check if your wi-fi adapter is installed(10/100 or 10/1000 is your LAN adapter, wi-fi adapters usually indicates something like 802.11x(could be agn or g or b) or the word "wireless". If you don't see anything I mentioned above that means your computer is unable to detect any wi-fi adapters installed. Know if you found a wi-fi adapter but there is a yellow exclamation or question mark, all you have to do is re-install the drivers for your wi-fi adapter(you can download the drivers on the Compaq website for free.)
2nd Solution:
Check if the wi-fi is disabled or stopped, if you have a bulit in wi-fi adapter on your laptop they have a wi-fi switch on the side or near the function keys(F1, F2, F3 up to F12). Wi-fi button/switch will have a logo or marking of an antenna that has waves coming out of it and there is a LED light that will indicate if its on or off(for Comapaq laptops it's either a blue button at the front, near the function keys or at the front panel on the buttom edge.
If both fails then you may need to contact Compaq for further assistance.
Hope this will help you fixin the wi-fi problems on your laptop.
Regards
Nov 23, 2008 | Compaq Presario Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
