Question about kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor ()
I have an x-mark FH680V 23 hp kawasaki ZTR. It will run flawlessly part of the time and at others it misses out, loses power and backfires. I'm not sure but i think that one cylinder cuts out when it does this. It has new plugs, air filter & gas filter. There is no certain time when it does this. Sometimes you can mow for an hour and it will do it and then run fine again.
2 Suggested Answers
  • 252 Answers
SOURCE: my kawasaki 23 hp model
hi there
if you had the carby off and cleaned it out , was the fuel flow from tank to fuel pump ( if it has one ) good , and was the output from pump to carb good on cranking?
if so and the breather in cap is venting , it could be that the governor needs adjusting, possibly have got a spring in the incorrect position and there is no binding , pay to check , carby main jet closly for any obstruction. check the fuel level and float hieght .
most times hunt / surge is caused by obstruction to fuel flow , or governor
try holding the governor in a fixed position if hunt / surge still apparent - carby is causing fault
but if not governor setup is causing problem
cheers pauly46
Posted on May 28, 2011
KAWASAKI FH680V NEEDS CARBURETOR ADJUSTMENT
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki Engine, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.encoreequipment.com/wordpress/wp-content/uploads/2012/06/17hp_FH500V1.pdf
Kawasaki FH680V AS01 4 Stroke Engine Parts
Kawasaki FH601D Owner Manual
Kawasaki 23 HP Rough Idle FH680V
Jul 09, 2016 | kawasaki Engine FH680V-FS06S
23 hp fh680v motor wont start carb keeps filling up with fuel but plugs are dry
perform a compression test low compression will not draw in fuel into the cylinder see them blow head gaskets around 2500 hrs
Sep 24, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
23 hp Kawasaki FH680v engine losses power when engaging pto!
We had issues in the UK with issues like this, they would blacken and soot up the plugs and start to run on on cylinder, there was an internally vented carb rather than the externally vented carb to cure this.
Aug 10, 2012 | kawasaki Garden
1993 Kawasaki ZXR 750 is losing power
Hi, Craig and the usual suspects are:
1. Dirty or clogged air filter.
2. Faulty spark plug.
3. Bad Gas.
4. Improper oil level.
5. Improper chain adjustment and lubrication.
6. Low tire pressure.
7. Dirty or contaminated carburetor needs cleaning and tuning.
8. Clogged or faulty fuel pump or injectors.
9. Improper valve adjustment.
10. Slipping clutch.
11. Improper timing.
12. Low compression.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Loss of Power and backfire Help 92 ZX750 KawiForums Kawasaki Motorcycle...
zxr 750 running problems part 2
Kawasaki 1985 ZX600 Service And Repair Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
May 12, 2012 | 1993 kawasaki ZXR 750
My kawasaki 23 hp model # fr691v on a toro 50 inch ztr from home depot started back firing. there was dirt in fuel filter so I changed it. changed the plugs and new air filter. Cleaned the carb. now thw...
hi there
cheers pauly46
May 28, 2011 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
I Have a FH680v 23 hp engine on my mower and raw fuel is coming out of the exhaust sounds like a stuck float is my theory correct and if so is there a rebuild kit or just a good cleaning will do the...
Find the carburetor and take a look inside. Don't buy any kit until you visually inspect the bowl, float and seal. The float could have gas inside. If you can get inside the carb, then you may be able to see the problem. You are also right, it may need a cleaning.
Gary
May 08, 2011 | kawasaki Garden
Kawasaki fh680v 23hp will not start at random. Coils are good, fuel pump, filters air and fuel, plugs and battery are all good. Valves are adjusted correctly and one head gasket has been replaced. It will...
Check solenoid on the back of carb! I just had a similar issue with the same motor, would start rite up but had no power! new fuel pump coils, plugs ect I found the ground wire going to the coils were zip tied to manifold and rubbed through on the underside of wire never saw it 2 days later ripped it apart again and bingo found it taped it fixed problem.
Aug 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor () Logo
459 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
