Question about ASUS P5GD2 Deluxe Motherboard
P5GD2 Deluxe motherboard in my PC. Recently I installed windows 7 (32bit) and everything seems to work fine except that there is warning that no audio device is connected
  • ASUS Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 24, 2011
I REQ DRIVERS FOR ASUS MOTHERBOARD MODEL P5GD2-TMX/S WITH WIN-XP PROFESSIONAL O/S.
http://download.cnet.com/asus-a7v133-bios/3000-2098_4-10163294.html
http://download.cnet.com/asus-agp-v3800-series/3000-2108_4-10163292.html
http://download.cnet.com/asus-v7100-series-display/3000-2108_4-10163299.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)exceptions are numbers and ) / - also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you also service pack 3
http://www.microsoft.com/windows/products/windowsxp/sp3/default.mspx
service pack 3
Sep 07, 2011 | ASUS P5GD2 Deluxe Motherboard
I need ASUS P5GD2-TMX/S desktop board drivers for xp
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Aug 19, 2011 | ASUS P5GD2 Deluxe Motherboard
Bad flash
change cmos settings to clear take out battery for one min. then reset cmos jumper again that sould work jim
Feb 27, 2010 | ASUS P5PE-VM Motherboard
ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
Jan 28, 2010 | ASUS P5GD2 Deluxe Motherboard
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows install...you only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
While running the computer all of sudden switched off
If your PC SMPS is ok then your PC motherboard has been faulty. pls checked it from service center.
Oct 13, 2009 | ASUS P5GD2 Deluxe Motherboard
Boot system from external hard-disk with USB2
You can check the bios and make sure that it is set to boot from USB. Turn computer off. Turn back on and immediately press F2. This will get you into the BIOS. Look around and find boot properties. Set the boot first to USB. If you do not see the USB option, then your motherboard doesn't support the boot from USB option.
May 09, 2009 | ASUS P5GD2 Deluxe Motherboard
Can't connect to internet after Windows XP reinstall.
Asus doesn't make it easy LOL. Here's the link you need to download the LAN files (and any other devices not working). When you click on the link, scroll down to XP and you'll get a list of drivers for this Motherboard. Best of luck to you!
http://support.asus.com/download/download.aspx?modelname=P5GD2-X&SLanguage=en-us
May 02, 2009 | ASUS P5GD2-X (610839128686) Motherboard
HOW TO ENABLE PCL SLOT IN ASUS P5GD2-TMX/S
The PCI slots on your motherboard are always enabled. The only exception is the PCI Express slot (intended for a video card), and in that instance, you need to go into Setup when the system boots, and tell it to use the PCIe for graphics, rather than the onboard port.
Cheers
Nov 13, 2008 | ASUS P5GD2 Deluxe Motherboard
ASUS P5GD2 Deluxe Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
