Question about Lexmark X6570 InkJet Printer
I have just changed both the colour and black cartridges in my Lexmark X6570 printer. The printer acknowledges that there are full cartridges but when I aligned the colour all that was printed was grey - no colour. When I tried to photocopy in colour I only got grey. I turned it off and tried to reset but same thing. How can I fix the problem. It was working fine until I changed the cartridges. Thanks, Sharon
    Master:
  • Lexmark Master
  • 956 Answers
Silly question, have you inserted cartridges in their right compartment?
Id yes!, To save yourself time, suggest you remove printer prog and reinstall latest update from Lexmark, rememeder to leave printer switched on while setting up
Posted on May 24, 2011
Lexmark x6570 print black on colour cartridge
In your control panel, devices and printers, click on your printer. you can make it print black from there
Apr 04, 2012 | Lexmark X6570 InkJet Printer
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
Where are the instructions on how to replace the black cartridge on the lexmark 6570
Hello. There's an article in the Lexmark website on how to change the cartridges on Lexmark inkjet and All-In-One printers. It has some graphics, as well, for you to better understand the instructions. Just click on this link: http://bit.ly/ccjYCZ . The printer shown may not look like your printer, however, the steps are the same. Hope this helps.
Mar 25, 2010 | Lexmark X6570 InkJet Printer
Where is the ink cartridge location on the Lexmark 6570
Please go to the Lexmark website, www.lexmark.com >Technical Support.
Do a Product search for the X6570. That will bring you to another search screen Enter this item number ENUS32244 and you will get back a detailed discription of the cartridge change process.
Don
Jul 09, 2009 | Lexmark X6570 InkJet Printer
Clear paper jam but there isn't one!
Try lifting the main cover as if to access the ink cartridges. Make sure that a) the printer is switched on, and b) the ink cartridge carrier is out of the way. Right in the middle of the bay looking down onto it, you'll see a small black plastic peg not much bigger than the end of a ballpoint pen situated over a silver coloured roller. Use a small implement to push the black peg downwards. No force is necessary to do this, so if it won't push easily don't force it. Once pressed down, the printer should operate normally. I believe the small peg is a mechanical device to inform the printer that there is paper in the tray, when of course there isn't. Try it out. Let me know if it works. As I spent ages trying to fix mine and it worked for me.
Jun 18, 2009 | Lexmark X6570 InkJet Printer
My Lexmark Z600 has stopped using the colour 27 cartridge. On test print it only shows black test lines and on a colour picture it prints black. When printing it shows the colour cartridge as full. I have...
apparently the default printing color has been changed, you have to change it back either from "control panel/ printers /right click on your printer and click properties, and choose color for printing." or you can do it per printing job, when it shows u the printing options, (like number of copies and other (basically same window from the control panel). if you do it from the control panel whatever you choose, that would be the default, otherwise it is per job change and is not permanent.
Jun 18, 2009 | Lexmark Z600 InkJet Printer
Lexmark printer x6570 unable to allign after putting in new cartr
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Feb 01, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X6570 InkJet Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
