Air conditioner doesn't get cold until driven on highway for appox. 30 minutes. Any idea why ? Must i take it to the dealer ?
  • 520 Answers
No You dont have to take it to the dealer. the chances are that you are low on freon (refrigerant). you have two options if this is the case. One is you can fill it yourself. Go to any Walmart or K-Mart and get a refill kit. The freon now is 134A. The instructions are on the package and its very easy to do. If you have a older car that takes R-12 then you must go to a shop.
Second choice is to go to any repair shop that does Air Conditioning work. Usually going to the dealer is much more costly.
If this does not fix your problem then you have a more serious problem and will need to go to a shop.
Posted on May 24, 2011
97 aerostar transmisson problem
I had trouble with what seemed like a transmission on my ford van. Was told by a master mechanic to disconnect the NEGATIVE battery cable for 5 minutes to reset computer. I did this, it worked & never had another problem with it. Maybe it will work in your situation. Doesn't cost anything to try!:)
Jul 21, 2013 | Ford Cars & Trucks
After highway driving for 2 hours and stopping for gas the car would initially start and then stall, it would run again until the car cooled for 30 minutes.
Sounds like your coolant level might be low. At highway speed you probably have enough coolant and with the air passing thru the radiator keeps the temp down, but at idle not so much. Or depending whether you have a belt drive or electric fan. Belt driven, could need a new belt.
Apr 06, 2017 | 1991 Mercury Colony Park
The car starts when cold, after driven and the engine is cut off, it won't start back for 30 minutes or more. Could you tell me why?
Sounds a lot like a bad coil. If not that, it could be a bad TPS throttle positioning sensor. I had a bad coil though do the same thing to my car
Jan 14, 2013 | 1994 Buick LeSabre
My air condition is not getting cold it turns on but it doesn't get cold
you need to charge the a/c unit. you can purchase a charge kit from your local auto parts store for around 30$ just follow the instructions on the can and you should be up and running withing a few minutes
Mar 21, 2012 | Kia Sorento Cars & Trucks
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Danby Heating & Cooling
I have an 86 MR2 that runs great but will shut down when driven for 30 minutes or so on the highway. The check engine light comes on from time to time and goes out once I decellerate. I found out that the...
Sounds like two issues. The O2 sensor would definitely do the light coming on and off (I have that problem on my MR2 currently). You can jumper the diagnostic ports to flash a trouble code on the dash (my O2 sensor is number 5). And, no, it should not cause the engine to shut off (it automatically uses default air/fuel ratios) I would make sure, however, that there is no bare wire touching somewhere. Now, the other problem sounds like an electrical issue, but it could be caused by heat - what happens with spirited driving at non-highway speeds for the same period of time?
Jul 18, 2011 | 1986 Toyota MR2
I have a 2002 Nissan altima,and the fan works an all and the heater works fine but turns the knob to cold but doesn't blow cold air,firestone told me there was probably a blockage somewhere and bring...
Could be that or the air conditioner clutch is not engaging or the compressor low on freon or a fuse is blown to the compressor. Auto air conditioners are always a mystery to solve. It's done by a process of elimination. Take it to Firestone or your Nissan Dealer's Service dept. Firestone, will generally be a little less expensive than the dealership. But, with auto AC units, knowledge is power.
Jun 22, 2011 | Heating & Cooling
Air conditioner won't work added freon changed low pressure switch compressor comes on when jumped across at low pressure switch just no cold air
The low pressure switch turns on appox 26 psi. If the pressure is lower than that, it wont work, you have a leak.
Jun 03, 2011 | 2001 Chevrolet Silverado 1500
I own a 2002 Sierra 4X4 5.3 with 130,000 miles. Recent repairs in the last two months: Cad. converter, fuel pump and OEM gas cap after codes alerted the shop of these failers. Now I'm getting P0141 and...
You have oxygen sensor problems. They wear out pretty regularly and do the "cold weather dance" you described. I'm surprised shop that replace Cat converter didn't address then. They usually go "hand in hand". Shop must have been trying to save you some $$$
Feb 27, 2011 | GMC Sierra 1500 Cars & Trucks
Coleman airconditioner
Try testing the capacitor (there may be 2 ) If the start windings can't kick out it will blow the breaker.
Jun 23, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
