Question about Malber TD700 Electric Dryer
Dryer is not blowing hot air. There was water collecting in the vent hose which was emptied, but didn't help. Probably a heating element but not sure.
  • Malber Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';';'
Posted on May 25, 2011
Clothes aren't getting dry
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Mar 30, 2014 | LG Tromm Electric Dryer
Maytag Centennial Dryer (MEDC400VW) not drying properly
First of all, please make sure the vent is clear all the way through. Next the vent must be straight as possible. Next it can not be to long. People think that because they feel the air outside the vent is clear, not always true. The vent can be partially clogged. So make sure. Next, if the vent hose has sags or bows and even tight turns. It can accumulate the moisture in it from the drying proceed. If water has collected in the vent hose the clothes will not dry properly. If the vent is to long it can not dry properly either, the blower on the dryer can only move air so far. So the shorter the better. If all of these requirements are meet. Then, I would have to start checking the thermostats. I hope I have helped you. Please respond if you need further assistance.
Jan 29, 2014 | Maytag Dryers
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
While drying water puddles from underneath the dryer and also drips from the control knobs.
If your dryer is leaking water, then you have a serious clog in the exhaust vent ducting somewhere. The water comes from condensation inside the dryer exhaust. As your clothes dry, warm moist air is exhausted out the dryer exhaust vent ducting. If you have any kinks, excessive bends, sags, or excessively long ducting runs, they can create choke points for lint to accumulate. Once the lint accumulates, it begins to collect moisture. As it collects moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becoimes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope this helps you.
Dec 30, 2009 | Kenmore 700 6972 Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryer will not produce hot air. What could be the problem? I opened the back panel and there is a square shaped box that was hot. Is that the heat element?
The heating element should be nearly the diameter of the drum and is generally round. If the box of which you speak is about 4 to 6 inches square, it is probably an electrical connection box and shouldn't be getting hot. If this box has a removable cover, unplug the power cord and remove the cover--look for loose connections. If all ok, replace cover. Does the drum turn? Start the dryer and check for air blowing from the outside vent. If not, check for plugged lint filter (wash with hot water and detergent) and lint plugging the flex-hose between the dryer outlet and the outside vent. After running for a little while, feel the back of the drum to see if is generally hot--if so, then the heating element appears to be working. Hope this helps.
Jul 26, 2009 | Dryers
No heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
Nov 26, 2008 | Dryers
Splendid washer and condensing dryer combo
Since the clothes ARE getting hot, it's not the tripped breaker(s) mentioned in Solution #2, because these would cut off power to the heating element(s).
Since it's a Condensing dryer, it can't be an obstructed exhaust hose, either (as there is no dryer exhaust).
Remove the lint filter(s). Holding it over a sink, see if water flows through it. The waxes in "dryer sheets" clog lint filters and, even though invisible to the eye, can totally obstruct the air flow and stop a dryer from drying. Wash it with soap and water.
Question: Does your dryer have a small drain hose leading out the back and going down a drain? If it's clogged, the dryer can't remove any more moisture. If there's no drain, then you have an internal "catch tank" to collect the water evaporated out of the clothes. It's supposed to be emptied after every load. Empty it.
If that's not the problem, I suspect your condenser is not working (removing moisture from the hot stream of air blowing through the wet clothes. This could be because: (1) It's clogged - Take out the boxy thing (technically called a heat exchanger) made of thin aluminum "fins" or tubes, and wash it off in the sink. or (2) The little fan that cools the condenser isn't running. In this case you'll need to call a technician. Good luck
Dec 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Malber TD700 Electric Dryer Logo
114 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Tim Whalen
Are you a Malber Dryer Expert? Answer questions, earn points and help others
