Question about Toshiba Computers & Internet
Log in and immediately log off
I have a toshiba satellite l35-s2174 xp media center laptop. it logs in and the desktop photo appears and immediately logs off. I tried using the recovery disk by pressing c and restarting, but it does not start up
  • 1,800 Answers
R insatll windows some dll files is missing thats all
and make sure that u format it with fat32
Posted on Aug 16, 2008
Clear cmos toshiba laptop satellite L35-S2174
Remove coin battery for 2 minutes, Computer will default to original new computer status. Make sure the 2032 coin battery is good.
Dec 26, 2012 | Toshiba Satellite L35-S2174...
I have a Toshiba L35 Satellite S2174. I lost my power adaptor so started to use a HP adaptor of same 19 V , but Different Current 3.16A. I dont have the current rating of my original charger. The...
Hi Arsalan
To answer your question Its "yes". wrong power/ampere rating can shorten the battery life. I recommend that once you replace the battery include the AC adapter.Thanks
Feb 20, 2011 | Toshiba Satellite L35-S2174...
I need the video driver for my toshiba satellite l35-s2366 laptop for windows xp
This driver should do the trick for you as the video on your laptop is a ATI Radeon Xpress series GPU.
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/integrated_mce-xp.aspx?type=2.7&product=2.7.2.3.2&lang=English
Robert from Blitware
Jun 11, 2010 | Toshiba Satellite L35-S2366 Notebook
I can't log into my Toshiba Satellite 4090XDVD Laptop?
Try 'Administrator' and "blank".
If you get logged-in, you can change the password for the 'User' ID.
Apr 25, 2010 | Toshiba Satellite 4090XDVD Notebook
When I attempt to log onto my network I receive this message. ''Windows was unable to find a certificate to log you onto the network (network name)'' This is followed by ''Validating Identity'' which when...
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.Switch the encryption to WPA-PSK (pre-shared key) on both ends and it will work.
Oct 11, 2009 | Toshiba Satellite 2400-S251 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
My Toshiba Satelite A105-S4211 wont log in
I recently ran into a computer doing this.
Try what jmagnu said, hopefully it will work for you (safe mode didn't help me).
I basically had to remove the hard drive from the computer, install it into another computer and run a ton of virus, malware, spyware scans on the drive.
I used a combination of AVG, superantispyware, malwarebyte's malware remover, hijackthis, ccleaner, and a few others who's names escape me.
Best of luck :)
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Desktop won't open
try to start in safe mode by pressing f8 during boot-up, then choose the administrator account and let windows load in safe mode. if you're able to load up to your desktop, restart your pc and log-in as you would normally do.
hope this helps!
Oct 23, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop continuously beeps when I get to log in area
Unfortunately beeps have different codes for different motherboards and unless you know what make it is; you are probably better to e mail Toshiba technical for help as there are no references on their knowledge base. Although this may be a memory fault or a processor/heat problem.
Jan 12, 2007 | Toshiba Satellite 2410-S203 Notebook
Computers & Internet Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
