Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
My psp is detecting an access point but not allowing me to select it. What must I do?????
  • 35 Answers
The access point must have security settings that are NOT COMPATIBLE with the PSP. You need to change the settings of the router (I would go with WEP) and it should work without issue.
Posted on May 24, 2011
How to update a psp 3001 via internet
firstly you must have a wireless router that supports wpa-psk or wep settings always remember that psp 3001 does not supports wpa-psk 2 settings
Now open the system update in the settings and then select new connection there are four options for u select the first one(scan)after a few seconds the access point from the router is detected on your psp select the access point there after configure the settings your connected to the internet (enjoy ;- )
Aug 20, 2012 | Sony PSP 3001 Game console - Black w/Games
Psp keeps saying no access point detected when I have wireless internet 3 feet away
Hi
Make sure your wifi is switched on, on your Psp. It's the little switch on the left hand side of the psp above your memory card slot.
Also check your router settings to make sure your ssid is visible.
If thats ok you may be running an old firmware on your psp which will only work on wep encrypted wifi connections.
Another point to remember is that the Psp will only connect to a network running on 802.11 b. It will not connect to an 'N' or 'G' enabled router. Saying that it will pick up and show a 'G' network it will not allow you to connect though.
Jan 10, 2011 | Sony PlayStation Portable (PSP) Console
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
HOW DO YOU GET ON LINE WITH A PSP
Step1 – Go to Settings and then select Network settings
Step2 – Select Infrastructure Mode and start a [New Connection]. By setting up in Infrastructure Mode, you will be able to take advantage of the more exciting features of the PSP, such as browsing the Internet and playing games online with your friends.
Step3 – Access the WLAN Settings and select scan to search for an SSID of nearby access points. If you find more than one access point, simply connect to the one with the strongest signal.
Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
Step5 – Now you have a couple of choices of either Easy or Custom in Address Settings menu. I suggest you selecting the Easy option which will complete the Infrastructure Mode set-up automatically.
Step6 – Choose your Connection Name and enter it. A Setting List will be displayed. Press x button to save settings.
Step7 – Test Connection to make sure everything works. If all is okay, Network Settings will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
In a nutshell there we are, 7 simple steps to connect your PSP to the internet using a wireless router to enable you to start surfing the internet, playing games online with friends, exchanging pictures and downloading your favourite RSS channels.
Mar 05, 2010 | Sony PlayStation Portable (PSP) Console
I can't get the internet for my psp
FOLLOW THESE 7 STEPS
Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point2_bing.gif is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
Step7 – Test Connection to make sure everything works. If all is okay, Network Settings2_bing.gif will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
Nov 29, 2009 | Sony PlayStation Portable (PSP) Console
How do I get wifi on my psp
Nov 24, 2009 | Sony PSP (Piano Black)
How do i get on the internet with my psp
Ok First you have to make sure that you are in a WiFi (Hotspot) area because that is how the psp gets online.
  1. Step1 – Go to Settings and then select Network settings
  2. Step2 – Select Infrastructure Mode and start a [New Connection]. By setting up in Infrastructure Mode, you will be able to take advantage of the more exciting features of the PSP, such as browsing the Internet and playing games online with your friends.
  3. Step3 – Access the WLAN Settings and select scan to search for an SSID of nearby access points. If you find more than one access point, simply connect to the one with the strongest signal.
  4. Step4 – Once an SSID is found, select it (make sure you don’t rename it) and move to the WLAN Security Settings. You should note that if the access point is using WEP encryption, you will need to enter the WEP key manually (when the access point is detected, it will display the type of encryption it is running. WEP key should be displayed on your router. If it displays none, simply move onto the next step.
  5. Step5 – Now you have a couple of choices of either Easy or Custom in Address Settings menu. I suggest you selecting the Easy option which will complete the Infrastructure Mode set-up automatically.
  6. Step6 – Choose your Connection Name and enter it. A Setting List will be displayed. Press x button to save settings.
  7. Step7 – Test Connection to make sure everything works. If all is okay, Network Settings will display Connection Name, Signal Strength, SSID, BSSID, Channel, Security and IP Address.
Sep 09, 2008 | Sony PlayStation Portable (PSP) Console
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Internet connection of psp
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue. For more information, see Using the On-screen Keyboard.
Mar 25, 2008 | Sony PlayStation Portable (PSP) Console
WIFI does not work: internal error 00000001
dont worry its no problen sony did not encode the higher versions it should say no network found but but it is the same thing so dont worry
Oct 05, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
