Question about Ingersoll Rand Air Tools & Compressors
Can't find any other size nozzels/tips for an
  • 2712 Answers
SOURCE: spray gun tips
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Posted on Aug 27, 2008
ivan6227
  • 35 Answers
SOURCE: Ingersoll Power Force PF235 Question
If you want to have the use of it for a long time you have to clean it realy well every time you used it. I assume you used it to paint oil based paint in which case you have to use the same liquid that you used to thin the paint, like therpentyne or thinners. After washing the excess paint out, blow some of the thinners through - about 200ml. To make sure there is no paint inside on the needle and the spring, take the bits out and make sure they are clean. You can spray it with some 3-in-1 oil to make sure it's not stuck when you want to use it again. It might not be practical for you with this model but I always left some of the thinning liquid in the bottle. Also, if it is possible, I took the nossle off and left it in the this bit of thinning liquid.
Posted on Nov 01, 2008
evwood
  • 50 Answers
SOURCE: vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Posted on Feb 04, 2009
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
  • 136 Answers
SOURCE: i need a user manual for a ingersoll rand spray
here is a link to a pdf file for the users manual.
http://www.irtechpubs.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Miscellaneous/45535887_ed1.pdf
And this is a link to the pdf file for the parts manual.
http://www.irtechpubs.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Miscellaneous/45547940_ed1.pdf
Posted on Jul 08, 2009
Small leak from gun of titan 400 advantage
Try reduce the pressure or change the spray tip seal areyouusingthe correct size tip for the paintyou are sprsying
Jul 14, 2013 | Titan Advantage 400 Airless Paint Sprayer
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
What are the controls of a gravity fee spray gun
most spray guns are basically the same gravity feed is no different, air pressure into gun and out nozzle,spray pattern fan to spot and last the amount of fluid comin out of cup to the nozzle.
Aug 28, 2009 | Ingersoll Rand 1.4MM HVLP GRAV FEED SPRAY...
BROKEN PART 270G
buy a new gun, parts wil cost as much as a new gun, beside having to hunt forever for parts( all most impossable to find!)
Aug 05, 2009 | Ingersoll Rand HVLP Gravity Feed Spray...
IR 210g - using thicker paint
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Nov 19, 2008 | Ingersoll Rand Hvlp Automotive Spray Gun
Aug 27, 2008 | Ingersoll Power Force By Rand PF235 Touch...
Thiner how to
Paint to thinner ratio is 60:40, that is 60% paint and 40% thinner. Sometimes it can be 50:50 depending on different occasion. Remember to MIX IT WELL.
Aug 27, 2008 | Viking Spray Gun: Hvlp Siphon Feed Spray...
Spray gun support
Daily clean-up all parts with proper cleaners/solvents. Re-lubricate where lubricant is washed away by cleaning. Moisture traps and compressor tanks must be drained daily.
Aug 27, 2008 | Viking Spray Gun: High Pressure Spray Gun...
Air Tools & Compressors Logo
35 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
