Question about Brother GX-6750 Typewriter
The typewriter is not displaying the numbers or letters that I want to type. How do I reset the machine?
  • Brother Master
  • 3,594 Answers
If it isn't in in KBII oe a language mode the Print wheel homing pawl nis probably broken.
DickyO
Posted on May 25, 2011
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
My Canon QS 310 typewriter has been programmed to type letters instead of numbers. How do I get the numbers back?
Turn off machine. Let it sit for one minute. Hold down ALT and CTRL key with left thumb and forefinger while striking letter a with right forefinger. Hopefully, this will "de-confuse" memory.
Apr 04, 2012 | Office Equipment & Supplies
I cannot type numbers? how do i reset or what keys should i use so i can type numbers/figures?
the numbers should print just by hitting the key, just like the letters. if the keys are just dead, you may have a bad keyboard or main circuit board. take it to a repairman or get a new machine.
Mar 21, 2011 | Brother GX-6750 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
Printing different letters
take to a repair shop or get a new one, no easy fix for this
Aug 21, 2008 | Brother GX-6750 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Different letters despite what I am typing...
look for kb1 and kb 2 or your pitch is selected at ps instead of 10 or 12
May 19, 2008 | Brother GX-6750 Typewriter
Printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Apr 28, 2008 | Brother GX-6750 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother GX-6750 Typewriter Logo
22 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
