Hi I have a carrier split unit Heat Pump model 38VYX080N. It works o.k in Cold mode but when I use it on Heat mode the Compressor shutsdown after a few minutes..fan inside and outside keeps going. changed the outdoor Electronic Board, compressor,most of the sensors but no luck.
    Problem Solver:
  • 12 Answers
Sounds like you have a blockage or a bad check valve. May also have an incorrect refrigerant charge.
Posted on May 25, 2011
My carrier hotel style heat/ac unit just blows cold in electric heat or heat pump setting
check the thermostat also check the inline fuse for the electric heat coil . check wires in control panel they tend to burn and last check to make sure reversing valve is changing over located by the compressor
Mar 05, 2015 | Carrier Heating & Cooling
Carrier heat pump
Expansion valve is sticking shut
Jun 13, 2013 | Carrier 5 Ton Complete Split System Heat...
M/n 38brb060300 carrier
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 15, 2010 | Carrier 38CKC060 Air Conditioner
Can't seem to get the compressor to come on. When
hi how are you...you say your outdoor unit is not working...is thermostst set in heat or cool when this is happening....if the compressor is running,go outside put your hand on the big copper line,if it is hot,your in heat mode,if it is cold your in cool mode..is it heatpump or ac only...if ac only ,you have a sequencer stuck ,or contactor closed keeping heat on...please chek items first...michael doctor airr appl.repair 843-384-8474...if need help call,ill help talk you diagnosis of problem...
Mar 27, 2010 | Carrier 38CKC060 Air Conditioner
''EMI'' heat w/ac acts weird.
Hi, what you have here is a ductless heat-pump split system. In the heat mode the compressor will run on a heat pump as it uses a reversing valve to reverse the flow of freon to heat your house. If it gets cold enough, the stat will call for the emergency heat strips to energize to come on for back up. Now, if the unit does not come on or go off when the thermostat calls for either heat or cool to come on and it just does it whenever it wants to, the stat will have to be replaced with a new one. If you plan on doing this your self, I would get the exact same heat-pump stat as you have because they make so many different models that the wiring may be much different and you will be lost when you go to wire it up. The heat - pump has many more control wires on them then the conventional heat/ac unit. So make it easy on your self and get the same one. They are easy to replace. If it is ignoring the settings its the stat. Heat strips and compressor running in the heat position together are normal for a heat- pump.
Sincerely,
Shastalaker7
Mar 17, 2010 | Heating & Cooling
Fujitsu split system not working
Hi, I know its a split as you have noted, and I am sure it would be a ductless heat pump system. Unless you are having a problem programming the t-stat, the manual would be of little help on these units.I wish you would have given more on the symptoms, like does it blow cold air or either unit will not work? You say it will not heat. On a H.P., it could be many things.Lets say its blowing cold air. Check the outdoor unit to make sure it comes on in the heat mode also, and the fan is on.Make sure you turn the heat up far enough to bring on the outdoor unit 1st. If it doesn't come on, then find the breaker to see if it is tripped. If yes, turn off hard and on again hard. if it stays on, great. If not, then It gets more complicated as compressor may have shorted out. Please check these things for me, please so we can solve this for you. On a heat pump, if you loose a compressor lets say, you have electric heat strips in the indoor unit that should come on if you have a switch on the T-stat that will say emergency heat. Try and use this setting to see if you can get some heat. I am trying to offer a solution to get you some temp. heat until we locate the main problem. If the indoor or outdoor units are not running at all, check for power at all breakers, and, check program on t-stat to make sure you set on heat, fan to auto, and temp to where you are comfortable.From here after checking all of these solutions, let me know what the status is and if it did not work, to tell me more of the original symptoms so I can go from there. Best of Luck,
Sincerely,
Shastalaker7
Nov 21, 2009 | Heating & Cooling
Heat Pump no longer produces cold air. Blows good but not cold.
make sure the coils are clean run unit a bout 20 min take cover off and feel the lines on the compressor the big one should be cold and small hot feel top of compressor to make sure running
if big line not cold most likley freeon has leaked out if compressor not running low psi may have unit out look at the compacitor if swelled up bad hope this helps
May 22, 2009 | Heating & Cooling
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
216 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
