My vizio 42" galleria wont
phongnv
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
djchillsnyc
  • 152 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
  • 13 Answers
SOURCE: Vizio TV 2006 vx32Lhdtv doesnt work.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
Testimonial: "If all things are equal than the solution is at hand. I thamk you!"
SOURCE: vizio vw42lhdtv10a 42
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Posted on Mar 16, 2010
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
Vizio vp422 orange light stays on wont power up
I would double check the capacitors on the power supply board. Make sure you don't have any that are bulged at the tops. Secondly, when you try and turn it on, does the orange light flash at all??
Jan 20, 2013 | Vizio VP42-20A 42 in. Plasma TV
I have a vizio tv and it wont turn on it showed the vizio logo and now it wont turn on and its been like this for 2 days
The main board will need replacement. Its very common issue where the set will freeze at the vizio kogo then eventually it wont turn the logo from orange to white so it can power up. Replacing the main board should solve the issue. You can get the replacement main board from www.tvcircuitboards.com
Jan 03, 2013 | Vizio L32 32 in. LCD HDTV
Vizio M420NV Wont turn on
I have a suggestion if you have and are using a box of some kind with this set, remove set and box from power for awhile and then power both back, sometimes a box can trigger this type of event, hope it helps and it cannot hurt to try.
Dec 11, 2012 | Vizio m420nv 42 in. LCD HDTV
Tv wont turn on fuse is good
does the vizio logo light up orange ? If so and it doesnt turn white then the main board would be suspect. If the logo doesnt turn orange when its pluuged in then its the power board. You can get either board from www.tvrepairworld.com
Aug 12, 2012 | Vizio VO47L 47 in. LCD TV
Vizio m470nv will not come on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
Mar 03, 2012 | Vizio M470NV 47 in. LCD HDTV
No power at all, vizio logo not lit,
Hi if nothing is coing up at all then you provably have a power supply issue.
You can get parts for this tv at www.interliquidparts.com
Mar 02, 2012 | Vizio GV42L 42 in. LCD Television
Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Apr 09, 2010 | Vizio VX42L 42 in. LCD TV
My Vizio is plugged in to a good power spource but will not turn on. The orange vizio logo on the front panel is not lit. Has anyone else had this problem?
No standby light meaning that you have no power connect to TV, check voltage at your outlet. If it has, your TV need to check the power supply board inside.
Aug 17, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
