On start up only asus a8vx page comes up doesn't boot os and has green screen which hangs then goes back to asus motherboard page. can not even use safe mode bt f8 goes right back to motherboard page.
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Posted on May 24, 2011
Asus p5vdc-x will not boot up
Press F8 during boot and go into Safe Mode. The roll back with System Restore. It is located in Start > Programs > Accessories. Or a link in help under tools.
You may have to try a few dates. This should help, if not repost with erros or more details. gl
Dec 27, 2012 | ASUS P5VDC-X Motherboard
My Asus F9e doesnt start anymore. Not even in Secure Mode. What should i do ?
Did you get any error messages? Since the BIOS is available, the problem is likely with the hard drive or it's trying to boot from non-bootable media (DVD, flash drive, USB connected floppy/hard drive). Since you can access the BIOS, look for the Boot Selection Order and make sure that the hard drive is first in the list. If the BIOS doesn't see the hard drive, it may be bad or have a bad power or data connection. (You can try opening the computer and reseating the cables - see Asus for any assistance. I am not informed on opening the F9e.)
If the hard drive is seen by the BIOS:
Disconnect any USB devices (and the optical disc if it is in the drive). Turn off the computer. Unplug the notebook from the power supply and remove the battery. Wait 10+ seconds (or a few minutes) then reconnect the battery and then the power brick. Try restarting the computer. (This is a hard reset.)
What do you see on the computer screen? If you see a blinking cursor, the computer doesn't have the boot manager available (either corrupted or a new disc that hasn't had the OS installed). Use a Windows install/upgrade disc/system repair disc for your OS version (the service pack must match) or a third-party disc management tool to attempt to repair the boot manager.
You will need the optical drive as the first boot device in the BIOS or press Esc to access boot order list. (On some computers, it's F12.) For Vista or Win7, boot from the CD and follow the on-screen directions until you see a list of choices. If the hard drive was previously working, click on Repair your computer. Select the OS to repair then click Next. Select the Command Prompt option. Type in bootrec /ScanOs to get a list of available Windows OS versions on the hard drive. Use the command bootrec /FixBoot to fix the master boot record. The command bootrec /RebuildBcd will rebuild the list of Windows OS versions. See http://support.microsoft.com/kb/927392 for details.
Installing a new hard drive and reinstalling the OS may be needed if you have a SMART or AHCI/SATA hard drive error. If you have a back up image, you may be able to restore that image.
I hope this helps. Please add a comment with any error messages for more assistance.
Jul 19, 2012 | ASUS Computers & Internet
When i start the laptop, only green lite indicate, but there is no display show's, & some time laptop start clearly, but after some time display get's hang or lines come on the display, or white or
Possible that PC is hanging up as there is fault on the OS (operating system) or a virus in the OS. Also it is possible that the backup battery (CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the PC boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service.
Dec 09, 2011 | Acer Aspire 4530-5889 Notebook PC
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
My Fujitsu laptop LH700 cannot turn on. When I press the start button, the battery or power indicator blinks for a second then goes off. There's totally nothing on the screen.I tried to on the laptop...
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
If the PC does not come on check the voltage on the battery terminal and the adaptor voltage. If there is no BOOTING then you must check the motherboard for errors.
If the PC boots up in any chance and tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
Sep 14, 2011 | Computers & Internet
I assume Dban worked.....worked so well I am froze at there very first screen {biostar mobo logo} and cant get any farther to load OS or even to the CMOS to even check settings......help pls
Once the drive is wiped that's about as far as one can get because there is no longer an OS to load. Power down the computer. Then turn it back on while hitting the "del" key repeatedly. If del doesn't work try the "F" keys, usually F2. Once in the BIOS, set the boot order for the cd/dvd drive to boot first. Exit using F10 to save. Insert your CD/DVD that has your operating system in the drive and reboot to install the new OS.
If you still can't get into the BIOS, power down the computer, unplug the power cord, remove the side panel and then remove the CMOS battery for 3 or 4 minutes. Put the battery back in and repeat the above instructions.
Jul 06, 2011 | ASUS Computers & Internet
A7V 400MX ASUS Mother Board: Problem
i had same thing - was power supply,,,,replaced and all fixed, now boots properly everytime
Mar 15, 2009 | ASUS A7V400-MX Motherboard
Building new computer with ASUS M2A motherboard and AMD 749 processor. Computer starts, displays ASUS setup screen, goes to blank screen with blinking cursor and then hangs up.
Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
Dec 09, 2008 | Computers & Internet
Occasional BOOT hang
Try using the event viewer and see if it comes up with anything
How To Use the Event Viewer Applet
http://www.bleepingcomputer.com/forums/topic40108.html
Jan 02, 2008 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
David Payne
David Payne
