Question about Diamondback Outlook 26" Mountain Bike
I can't locate the chain link which must be used to separate it for removal. It's been some time since I removed a bike chain, and from what I remember, chains used to have "master links", but evidently no more. Do I need a special tool to detach the chain? Son's bike is a Diamondback Outlook. Hope someone can help!
    President:
  • 2,080 Answers
Yeah, they generally don't have those Master Links anymore.
For most modern bikes you have to use a CHAIN BREAKER TOOL. See the following link for a picture and general price:
http://cgi.ebay.com/BIKE-BICYCLE-CHAIN-BREAKER-REPAIR-TOOL-NEW-/290563405472?pt=LH_DefaultDomain_0&hash=item43a6edb6a0
Here is a link to an online How To Guide on how to use a CHAIN BREAKER TOOL to break a chain and replace it:
http://www.bicyclinglife.com/howto/changeachain.htm
And here is a link to a short video on the process as well:
http://www.youtube.com/watch?v=n--fgqwuTTI&feature=grec_index
It is not an overly difficult repair so you should not have much problem with it even if it is your first time using the tool.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 24, 2011
Testimonial: "You're as smart and kind as the day is long, Joe. Thank you for such an excellent and informative reply. My bicycle helmet is off to you, Sir! "
  • Joe2
    Joe2 May 25, 2011
    Thank you very much for the 4 Thumbs Up, it's much appreciated. I'm glad I could help out a bit. Good luck with that repair job and safe riding. ----Joe.
Bike chain
With a chain splitter! It's a good idea to change the front and rear sprockets too so buy the lot when you're buying the chain. Loosen the tension on the chain tensioners on the rear wheel. Split the links. Remove chain. Remove and replace sprockets. Replace chain and be sure to use a chain riveter to sort out the joint. Don't be tempted to use a split link as your bike is too big and powerful for one. Adjust your chain tension checking for tight spots etc. Apply lube and enjoy!
Jul 14, 2014 | 1999 Honda VT 750 C2 Shadow
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Tip
How to Remove and Replace the Bottom Bracket on an Indoor Cycling Bike
Following is a basic guideline of removing and replacing the bottom bracket on an indoor cycling bike. Due to the different brands of indoor cycling bikes and designs for bottom brackets, the following should only be used as a guideline. If any of the information is not exact to the bike being serviced, refer to the service manual or call Sportsmith for further help.
Common Tools Needed:
Phillips Screw Driver
Set of Allen Wrenches (standard and metric)
Bottom Bracket Tool
Cotterless Crank Puller Tool
9/16" Socket
Ratchet Wrench
Pedal Wrench
Crescent Wrench
You will begin by removing the outside belt/chain guard by using either or both the Phillips screw driver and Allen wrenches. It may be necessary to remove the drive side pedal (using the pedal wrench) in order to completely remove the outside belt/chain guard.
Once the belt/chain guard is removed, you will need to remove the belt/chain. If the unit is belt driven, you can simply "walk" the belt off the pulley by pushing the belt to the outside while turning the crank backwards. **CAUTION: PINCH POINT ** If the unit is chain driven, most use a continuous chain that can be "walked" off the sprocket just like the belt. **CAUTION: PINCH POINT ** Some chains may use a connecting link and can be separated at the connecting link to remove the chain. The connecting link is different in appearance from all other chain links.
Now it is time to remove the crank arms. How to Use a Cotterless Crank Puller Tool
It works best to place the bike upside down for best leverage to remove the bottom bracket. (If placing the bike upside down, ensure proper seat adjustment for best bike balance.) Begin removing the bottom bracket from the drive side of the bike. This side has a reverse thread. You will need to turn right to loosen and remove the bottom bracket. Place the teeth of the bottom bracket tool into the teeth of the bottom bracket cup. Using the ratchet wrench or crescent wrench to turn the bottom bracket tool, you will turn right to loosen and remove the bottom bracket. (If removal of the bottom bracket is difficult, it helps to use a crescent wrench in combination with a bolt threaded into the bottom bracket shaft to hold the tool in place while applying pressure to break the bottom bracket loose.) Remove the bottom bracket from the frame. Remove the bottom bracket cup and/or lock ring from the non-drive side of the bike. This is a standard thread. You will turn left to loosen and remove this bottom bracket cup and/or lock ring.
Install the new bottom bracket from the drive side and tighten flush to the frame. Install the bottom bracket cup and/or lock ring to the non-drive side and tighten.
Re-install the crank arms and pedals. Make sure the crank arm bolts are tightened to the proper torque. If unsure of proper torque specs, refer to the equipment service manual or call Sportsmith.
Re-install the belt/chain onto the pulley/sprocket. If belt/chain was "walked" off the pulley for removal, it can be "walked" onto the pulley/sprocket by placing the belt or chain along the bottom of the pulley/sprocket. Carefully, turn the crank arm forward while lifting on the belt/chain. **CAUTION: PINCH POINT ** Continuing turning the crank forward until the belt/chain is in place.
Re-install the outside chain guard and test the unit. Ride the bike without tension and test with tension. Ensure functionality and feel of the ride. Make any adjustments if necessary
Removing and Replacing Bottom Bracket on Indoor Cycling Bike
on Mar 11, 2015 | Exercise & Fitness
I want to convert the bike to a single speed and need to remove several chain links. There doesn't appear to be a master link. Can it be done?
It can be done, but you have to buy chain tool first, it looks like this:
For instructions on how to use chain tool, see this video:
If my answer helped you, please take time to rate it :)
Sep 07, 2011 | Cycling
I do not know how to get the chain off of my bike does anyone know how to take it apart.
Bike chains have one link that you can take apart. Look at all of the links and you will find one that looks different. you can use a straight screwdriver to push the removable keeper off the link and it will come apart so you can remove the chain.
For more info:
http://www.bicyclinglife.com/HowTo/ChangeAChain.htm
Jul 03, 2010 | Cycling
How do i remove links in my power saw chain to make it the proper size.It's a new chain that's the right size for the bar .073 but is too long. I have an Oregon chain break and a shop to do it in. Do I...
Yes they sell links for that at the saw shop. You file the head off two rivets in the chain to remove however many links you need then install the connecting link. If you're not sure how many to remove, take out one at a time putting the connecting link in without bradding the rivets. Put it back on the saw and see if its still too long. When the length is right you brad the end of the rivets that come with the new link.
Mar 07, 2010 | Husqvarna Garden
I'm cleaning my MTB chain. I removed it from the front chain guard by taking out a screw. Now, it's all kinked up, and I can 't get them out.
a bicycle chain cannot be removed from the bike without breaking the chain using a special chain break tool or if the chain has a special link called a quick link that snaps apart. However, to clean a chain it does not need to be removed from the bike. Some degreaser, a stiff brush and some water as all that needed to clean the chain, then follow the cleaning with some good bicycle chain lube.
Dec 30, 2009 | kawasaki 73026-9 KDX126FS Dual Suspension...
I need to know how to adjust the chain tension
The only way to adjust the "tension" of the chain is to remove links. You will need a chain breaker tool. Shift the bike into the biggest chain ring and the biggest cog of the cassette, then break the chain, leaving the pin partially in the link but far enough out that the chain separates. Now, pull the chain together so that the rear derailleur's arm is as horizontal as possible and aiming toward the crank. Break the appropriate link to connect the chain so the derailleur stays in that position and reattach the chain using the pin you left partially engaged.
i hope this helps
-matthew
Nov 15, 2009 | Mongoose Tyax Comp Men's Mountain Bike
Can you tell me how to change the chain and sproket on a '07 Honda Shadow VLX 600cc???
I don't have any experiance with your particular bike but have changed them on many different bikes to date. You should first purchase a new chain and sprokets and compare them to the existing one prior to removal as you won't be able to refit the old one safely. You are checking for the correct amount of teeth on the sprockets and the amount of links in the chain.
Once satisfied that you have the corrrect parts. Remove the front sprocket cover and locate the front sprocket. Most large bikes will have a large nut holding it on. Smaller bikes will use a tab washer and or circlip. If you have a large nut i find the easiest way to loosen it is to put a lock or similar through the rear wheel to immobilise it and then with a breaker bar loosen the nut. Once free change the sprocket over, then move to the rear sprocket loosing each nut in turn but making sure you are appling pressure to the nut squarely as it is easy to cross-thread these smaller nuts. This is best achevied by leaving the wheel on the bike until all the nuts are free. Remove the wheel and change the rear sprocket. Once done you are now ready to remove the chain from the swing arm. You can either cut it off with an angle grinder or you a chain link tool as i do.
Now the chain is split. Connect the new chain to one end and feed it through. Detach the new from the old and then rivet both ends together using a chain tool as described in the tools specific instructions.
Regards
Chris
Nov 06, 2009 | 2005 Honda VT 600 CD Shadow
Bike is a 2005crf250x. Need timing chain slack.
Lift the chain with one finger then turn the crankshaft several full turns by hand. Inspect the full length of the chain during rotation. Any obvious damage? Does the chain revolve smoothly around your finger? If all seems okay then the problem is probably not in the lower end. Some chains are continuous and do not have a master link. Some do have a master link. If you have a master link then separate the chain by removing the link then place both ends of the chain onto the cam sprocket and reconnect the link. If you have a continuous chain I would need to see first hand what is going on. In any event, be certain the timing marks on the flywheel and overhead cam are correctly lined up during installation.
Feb 26, 2009 | 2005 Honda CRF 250 X
Diamondback Outlook 26" Mountain Bike Logo
269 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
