Question about LG LSC121PMA Split System Air Conditioner
When i turn on the air conditioner blows hot/warm air it does not chill
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Is bad if u don't put in window?
Yes, because the chilling process produces heated air and if you don't fully fit it into the window, the hot air comes back in. If you just sit it in the middle of a room or even near a wall, it will be blowing cold air out of the front and hot air out the back. Window fitting kits aren't expensive. You need to do it the right way.
Jun 22, 2016 | Heating & Cooling
Why is it blowing cold air?
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Jan 15, 2016 | Amcor Dehumidifiers
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
Jan 25, 2014 | Honeywell ER150B Air Conditioner
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
My air conditioner blows warm air when stopped and idleing
Possible problems.
Air conditioner blows warm air?
Possible solution, system may need to be recharged.
You also wrote, temp light come on, gauge reads hot.
First check coolant level, always check this first.
Next, check your radiator hoses.
Next, have your thermostat checked, or change it. Their rather inexpensive.
Good luck.
Jun 20, 2012 | Air Conditioning and Heat for Pontiac...
I just got an amcor CPLMB12000E fom a friend, it worked great for about 15 min. then the fridge turned on an blew a cecit breaker in the box. I reset itand all it does is blow harm air. I pluged it into a...
Check compressor and fan only things it can be disconnect one at a time until fault goes away and there is your prob hope this helps
Aircon chilling for a living....................
Sep 01, 2011 | Heating & Cooling
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
