Question about Garden
The blade will not turn on my Ranch King 6.0. I cannot budge the pull cord and can barely turn the blade manually. What can I do?
Check to see if it is if the cylinder is full of gasoline. remove spark plug and turn motor over.
caution, disconnect and ground spark plug wires, do not stand in front of spark plug hole, you may get sprayed with gasoline. spin motor with starter or pull rope.
if this doesn.t free up the blade look under it for "stuff around the drive shaft. clear it out.
other solutions are expensive and involve bent cranks.
Posted on May 24, 2011
I want a drive belt diagram for a ranch king pro riding mower?
It's easier to find the correct information with a model number.
I have found a owners manual listed under MTD 130-390A
owners manual for a 2002 ranch king riding lawn mower.
Hopefully this is the same as yours.
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=ranch%20king%20riding%20mower%20manual
Pages go right and left or click on download.
Aug 28, 2014 | Garden
Can I manually move the power adjustable pedals on my 2005 F150 King Ranch Crew Cab?
you can if motors are any good, the motors are reversable 12v only for a tempary fix.2 jumper wires and a 12v battery
Apr 15, 2012 | Ford F-150 Cars & Trucks
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
1994 MTD Ranch King 42"
sounds lke you do go to SearsPartsDirect.com punch in your model make and you can look up te belt
Jan 10, 2018 | Garden
Pull cord stuck
First. Remove the spark plug and see if any oil runs out.
Second, If the cylinder isnt flooded with fuel or oil. Make sure your blade brake is releasing properly.
Third. Remove the pull starter cover and consider putting a very light spray of WD40 onto the spring housing from the underside and work it around.....the recoil spring may just be rusted solid and a little lube and maybe a tap or too with a rubber mallet might just break it free.
I have seen all three conditions turn an otherwise working mower into something that wouldnt budge.
Good luck and be careful. Dont pull out the recoil spring as it under tension and could spring out and bite you or at least make a mess.
Jul 15, 2010 | Poulan "Poulan" Push Mower
I am trying to find info for a ranch king pro rear tine tiller, the engagement cable is broken and i can't seem to find any cable to replace it with or anything about a ranch king pro tiller, the engine is...
Looks like Ranch King Pro is made by MTD. The part is probably the same, but to be safe, take your old cable off and take it to a lawn equipment service shop to match it up. Shouldn't cost more than $10 - $20.
Jun 04, 2010 | Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Jul 10, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
