I am trying to back up files to my iomega Ultra Max 1 desktop hard drive, and I get a pop up saying the disk is either full (which it isn't) or it is protected against saving files. I also see an icon in the corner with a pen with a dash through it. How can I unlock it?
  • 27,725 Answers
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on May 25, 2011
Iomega hard drive won't let me view files on my TV
I have suggestion for you please scan your external hard disk with a good antivirus and then anti malware bytes. Possible your problem will be solved. Thank you so much....
May 06, 2012 | Iomega Select 1TB USB 20 Black External...
My computer recognizes my iomega usb hard drive, but cannot open the files.
here is the best way to get back lost files.
1.) Stop using the hard drive IMMEDIATELY! Do not drag or create any files on it.
2.) Download asoftech data recovery program: http://www.asoftech.com/adr/index.html
3.) Install and run the data recovery program against the hard disk
Good luck.
Sep 01, 2011 | Iomega (34959) 500 GB USB 20 Hard Drive
My hard drive was working properly earlier and now i plugged it into my laptop and it says that i need to format it for it to work, it shows the icon for it on my computer but won't open. I don't...
The disk is dying - hardware defect. Last attempt to save some of your files: take apart the casing and extract the actual hard disk from it; put it directly inside a desktop and try to access it from there. If the disk isn't recognized or you get an IO error when you try then the damage is too great. If you only get a format error you could try this program
http://www.ptdd.com/recoverdeletedpartition.htm
Jul 17, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
Regards, Chris
May 31, 2011 | Iomega (33090) 250 GB Hard Drive
My vaio laptop with windows XP will not "see" an
Hi mpetersen809,
When you connect your external hard drive, does Windows chime or show an "installing devices" pop-up in the lower right corner of your screen? If this occurs, but you can't see the drive under "My Computer," your external drive might be trying to use a drive letter that's already in use by another device. To resolve this issue, you can manually set the drive letter for your external drive:
  1. Right-click My Computer and choose "Manage." A "Computer Management" window will appear.
  2. In the right pane, under "Storage," click "Disk Management."
  3. Locate your external drive at the bottom of the right pane. Disk 0 is your laptop's internal hard drive, so your external drive will probably be named "Disk 1" or "Disk 2."
  4. Right-click the area of the drive that says "Healthy (Primary Partition)" and select "Change drive letter and paths."
  5. Click the "Change" button, then select an unused drive letter (like Y or Q) from the drop-down menu and click "OK."
  6. Click "Yes" to confirm that you want to change the drive letter.
  7. Close the Computer Management window, then open My Computer to see whether your external drive is visible.
If this doesn't work, there could be a problem with the external drive. Test the drive by plugging it into another computer. If the drive isn't recognized on the second computer, contact Iomega for warranty support or replace the drive.
May 17, 2011 | Computers & Internet
I have an Iomega external hard drive and I am getting a message: F:\ is not accessible. The disk structure is corrupted and unreadable. Can I retrieve my images from the drive? Thank you
Try it on other Port or try plugging it on other computer.
if its corrupted there's a way of retrieving the files. using a recovery software :).
you can use Seagate File recovery software. it will work on other devices .
May 10, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I connected the hard drive to my laptop, selected "open folder to view files", and I set up the iomega encryption utility. Now, when I try and actually put anything on the hard drive, it says...
It sounds like a couple of possible issues. One issue could be that the partition for the drive was accidentally set too low. You can check the drive partitions by going to:
Control Panel > System and Maintenance > Administrative Tools > Computer Management
Once you're in there, you can click on "Disk Management" located on the left. If you click on one of the drives, you'll be able to see the partitions of the drives at the bottom, represented by blue bars and the hard drive's name. If you right click on one of the drives, you might be able to click "Extend volume" to extend the drive. If not, try uninstalling the program that you recently installed onto the drive, and if even that does not work, try to format the drive.
May 06, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I bought this 1 iomega white external drive to back up my pictures, Now the computer is not detecting it, i have already plug it in another computer and Nothing, I have very valuables pictures inthere and...
Disassemble the casing, and disconnect the USB-to-disk-drive adapter from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some computer. If you are "lucky", the computer will detect the drive. If you are "unlucky", search online for "Data Recovery Service" -- these are high-cost services that can disasemble your disk-drive, repair it just long enough to copy your files onto another disk-drive (or DVD-writable media).
Jun 15, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
