Question about Schaerer Siena Espresso Machine
Which de-scaling solution is recommended for the siena-1 espresso maker
  • 1,089 Answers
Hi
There is a liquid called Durgol or you can use the powder which is citric acid. Not recommended using something that has a taste or you would use in the bathrooom/kitchen.
Posted on May 25, 2011
Why is it leaking during operation?
Could need de-scaling. Scale builds up after time and reduces flow rates, increasing pressure leading to leaks. Give it a go with any generic de-scaling powder or liquid following the instructions. My coffee machine (different model) did similar and now works like new again.
Aug 26, 2015 | DeLonghi ECO 310.BK Pump Espresso Maker...
What does de-scale mean?
De-scaling refers to removing mineral deposits that build up over time. These minerals are found in regular tap water with higher concentrations in areas with hard water. Run a mixture of 1 cup white vinegar to 1 quart water through the machine followed by 2 or 3 cycles of clean water to clear any buildup. If the buildup is heavy you may need to use a cleaning product designed for cleaning coffee brewers.
Apr 11, 2011 | Keurig B60 Coffee Maker
My coffee maker does not dispense the correct amount of water, regardless of the cup size I select.
Sorry to read about your problem, I hope this helps you out.
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Jan 01, 2011 | Keurig Elite B40 Coffee Maker
My problem is it only makes 1/2 of what is suppose; s
Dec 25, 2010 | Keurig B70 Coffee Maker
THE MACHINE ONLY BREW 1/2 OF THE LIQUID.THE WINDOW READS/BREWING/BUT THE LIQUID STOPS.I GOT TO SHUT THE MACHINE OFF,THEN ON,TO GET ANOTHER 1/2 CUP,BUT SOMETIMES DOES WORK AT ALL.
Dec 19, 2010 | Keurig Platinum B70 Coffee Maker
Does not dispence right amount of water
2,,2,2 you can contact Keurig at 1-866-901-2739 or Keurig.com
Dec 19, 2010 | Keurig B60 Coffee Maker
Thin stream of water, only does a partial cup
weqwqwqw5555
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
Instructions to descale Schaerer Siena
With the machine off remove the grounds bin ( leave it out ) the press & hold the cleaning button until the de-scale symbol flashes
May 14, 2009 | Schaerer Siena Espresso Machine
Schaerer Siena Espresso Machine Logo
Top Schaerer Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
