Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
I have a 2003, KF60WE610 60inch TV. My TV started occasionally losing the picture. The TV will go from normal picture to color patterns yellow/orange, green/blue, black and white. Then I'll have a black screen. The sound is fine. The picture returns without doing anything. The lamp light does NOT blink. The lamp was replaced a year ago. The green power light is steady. What could be the issue?
  • 643 Answers
Your optical block is going bad. Sony has made a recall and is offering to pay around 70% of a new tv. Call this # 1-800-282-2848 Hope this helps.
Posted on May 24, 2011
  • c130871 May 25, 2011
    Thanks. I was afraid it was the optical block. I just checked today and I don't have the lamp over heating issue, at least not yet.
Lose picture and screen flashes different colors and patterns
Not likely to be a do it yourself repair----Main board that processes all signals or even a power supply board can cause this issue.
Repair will consist of first ruling power board out and then at some point buying and replacing boards to see what is the problem----
sd tech
Apr 28, 2012 | Samsung LN32C450 32 in TV
After moving, my Philips HDTV doesn't show normal picture anymore. I can hear the sound but all it shows is many different color at once shifting down just the top of the screen (and it will do this...
The tv have a colors wheel design into it tv.The tv is now having grinding noises or colors pattern mess up or tv flashes of Black&White within the color picture.Mean the tv colors wheel disc it is worn out and it is not spinning inside it motor axis anymore.If u are not mechanically incline,don't tries to change the colors wheel by ur self,will cost u more problems,than it worth trying to save some money by trying to do the job ur self.Hire a bonded tv Tech.to do the job.The tv part and the labors should cost u about $500.
Jun 14, 2011 | Philips 50PL9126D/37B 50" DLP TV
My printer will print black ink, but when I try to print something with color, nothing appears. I have tried re-installing the color cartridge and restarting the printer. The test page says all ink levels...
I had the same problem. Unfortunately, it may not be fixable. The tiny pipes that carry the ink are REALLY small; about the thickness of a hair. As a result, they can clog. If you only occasionally print in color, the ink in the pipes dries out. You can't do the repair. I was told by the technician that I should print the test pattern occasionally, if I'm not printing in color often.
Jan 16, 2011 | Office Equipment & Supplies
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
Mitsubishi 60 in vs-60707
. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Picture Fades
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Jul 12, 2006 | Sony KP-57WS500 57" Rear Projection...
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
696 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
