Question about Pyle Car Audio & Video
Proper installation procedures from start to finish in a 96 geo prizm with a kenwood cd player
  • tony_sexysal May 24, 2011
    Thanks but the stereo is already installed. I am trying to find out how to install an amp and a 3200w PYLE subwoofer enclosed (dual port sub box) to a kenwood stereo
  • tony_sexysal May 25, 2011
    awesome thanks man
  • 1,940 Answers
You will need the following:
1996 Geo Prizm Radio Dash Kit
1996 Geo Prizm Radio Wiring Harness
1996 Geo Prizm Wiring Information
  1. First, starting at the top, gently pry off the console molding using a flat head screw driver.
  2. Next, with the radio exposed, there are some screws around the radio which you should unscrew and pull out the radio unit, you'll have to unplug the speaker wire from the radio to remove it entirely.
  3. I recommend you buy a face plate kit, and a speaker wire adapter plug.
  4. Match up the wires from the adapter to the new stereo's wires.
  5. Install the face plate, then attach the speaker wire plug on the geo to the new radio with spliced wire connection, then screw in the radio.
  6. Next, fit the center console cover back.
If you need the wiring for your Kenwood CD Player, I will need the model number. I hope this helps!
Posted on May 24, 2011
  • Jeremy Moore
    Jeremy Moore May 24, 2011
    You will need to run a Remote wire (blue wire) from your Head-unit to the Amp. You will also need to connect a Stereo RCA cable from your Head-unit to the Amp. If you don't have Stereo RCA Outputs on the back of your head-unit, you will need to wire the Amp inputs to your Head-unit speaker outputs. Next, you will need to run a power wire and ground wire, same size, from your battery to the Amp. Make sure your power wire has a fuse inline, no more than 12 inches from your battery. Now you can run the Speaker outputs from your Amp to the Sub box. If you need further assistance, let me know.
Where is the starter relay located on a 1996 GEO PRIZM?
Junction Block #1--Above Left Kick Panel--Info On Inside Of Cover.
Feb 26, 2015 | 1996 Geo Prizm
Where is the starter relay switch located on a 96 geo prizm
double posted as anon?
here it is. , now twice.
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=231&fml=105&brd=6623&thid=25486529
Procedures on replacing clutch pressure plate and release bearing on 96 Geo Prizm 1.6 liter
Here are a couple of very detailed videos:
Rock Auto is your best source for parts. 1996 GEO PRIZM Clutch Kit
Jan 31, 2015 | 1996 Geo Prizm
Procedure on clutch kit replacement on 96 Geo prism 1.6 liter
See your other post for the answer; no need to ask twice
If my car wont start do I need a fuel pump 96 Geo Prizm
Could be battery, ignition or fuel? Have it checked by a garage!
Nov 16, 2014 | 1996 Geo Prizm
Front door panals 96 prizm
they snap off, start in lower rear corner, pull gently , pop goes the rivets.
once one pops, you now have the idea... yes, more.
Mar 20, 2013 | 1996 Geo Prizm
Engine light on my 96 Geo Prizm
Cant know until you have a code to look at. Take it down to your local autozone pepboys or O'reilly's auto parts stores, they will read the codes for you free of charge
Apr 26, 2010 | 1996 Geo Prizm
Need to replace the starter on a 1994 Geo Prizm
starters are actually pretty easy. usually just 2 or 3 bolts holding it on. Just disconnect the battery first. Remove the bolts and the starter and then installation is reversal of removal.
Hope this helps,
Lee
Sep 15, 2009 | 1994 Geo Prizm
Trying install new cd player unable to match wires YEAR OF CAR: 2001 MAKE: GEO PRIZIM
go to a radio install shop,tell them your problem they might sell you the part you need to complete you install.
Aug 11, 2009 | 1995 Geo Prizm
Where do I add tranmission fluid on a 96 geo prizm
If you do not see a dip stick then you will have to look under the car, it will be a 17mm inset nut, have the car running in N when putting the fluid in
Jul 14, 2009 | 1995 Geo Prizm
Car Audio & Video Logo
263 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
