Question about Copystar CS-1810 Copier
My copystar cs-1810 keeps printing dark copies....I already changed the toner & plastic toner waste compartment....what should I do?
    Sergeant:
  • 372 Answers
Check the charging corona unit.it might be dirty of not aligned properly.clean it with alcohol
Posted on May 25, 2011
We replaced the toner cartridge and the waste receptical and the little red light "Add Toner:" is still on and the machine won't copy. We have removed the cartridge and did the dance...
If it is a Kyocera toner than that is the problem. The key to turn the toner is different for the Kyocera toner cart. It will fit and appear to work but won't. Also turn the unit off and unplug for 15 sec. will reset and perform boot up procedures might help.
Jul 07, 2011 | Copystar CS-1810 Copier
WHAT DOES CODE C7990 MEAN ON A COPYSTAR CS-1820
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Mar 30, 2011 | Copystar CS-2030 Copier
I am getting an AP error code on my machine
Add a new toner & waste toner bottle
Sep 01, 2010 | Copystar CS-1810 Copier
Copystar gs1810 replaced th toner but I can't get
The toner auger is probably clogged up. You will have to disassemble the whole dev unit to clean it out.
Jun 01, 2010 | Copystar CS-1810 Copier
Copystar 1810 GS
that's because it thinks it's out of toner. keep opening and closing the front door and let it run.
Jan 21, 2010 | Kyocera Copystar CS-1820 Black and White...
I just replaced the toner. Toner light on
Keep opening and closing the front door until the toner catches up. Did it have a plastic seal that you forgot to pull off?
Nov 25, 2009 | Copystar CS-1810 Copier
MY 1810, i GET AN "ap" FLASH THAT changes to "OP' I find no paper jam in the trey nor the back..Mike
hi
the AP means that the copier needs more than one cycle to add toner.
This usually happens when the copier is used for a whiile after the add toner message comes on
Aug 22, 2009 | Copystar CS-1810 Copier
My copies are coming out "blotchy"(with light spots).
Sounds like the machine needs a deep cleaning, and exposure adjustment...call for service
Mar 20, 2009 | Copystar CS-1810 Copier
Copystar CS-1810 instruction book
manual download link
http://usa.copystar.com/CopyStarPub/jsp/Kyocera/resource_details.jsp?rid=2076
If it only has lines on copys then
Clean scanner glass (small slit of glass before copy glass)
If it happens on prints and copys then it will more likely be drum.
Nov 10, 2007 | Copystar CS-1810 Copier
Won't print documents from computer! PLEASE HELP! ASAP!
You cannot use an IP number for more then one device. It is an unique identification number. On the PORT section uner the Windows driver, change the last three digits for the Copystar machine, do not change the other ones (keep in mind that it should be unique!). Then go to the copier and thorugh the user panel get into network settings and enter the COMPLETE IP number just typed in Windows. It should work.
Sep 16, 2007 | Copystar CS-1810 Copier
Copystar CS-1810 Copier Logo
65 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
