Question about Garden
Ryobi RY60520 Tiller- How do I fix the rewind starter?
3 Suggested Answers
  • 109 Answers
SOURCE: just tried starting my ryobi trimmer and the
if ti didnt retract chances are the spring is broken and will need to be replaced
Posted on Aug 23, 2009
  • 3074 Answers
SOURCE: My Yard Machine Tiller starter rope will not
you can either drill the rivet out, or inside the shroud there are metal tabs that you can bend out, but be careful as not to break them off. Hope this helped Tim
Posted on Feb 27, 2011
The pull cord on my Roybi rtl30ces will not retract. How do I access to repair?
Hi Kathy - more likely than not there's a little "tab" on the end of the spring that slips it to a tab in the plastic to maintain spring tension.
These break off fairly regularly and you can easily bend the spring steel to a 90 degree to "fix it" and place it back in the tab.
I've included a teardown / rebuild video that should be very helpful when repairing your weedeater - it's a "generic" ryobi video but they're all really, really similar.
Don't be intimidated - they're super easy to work on! How to Fix the Starter on Ryobi Trimmer
Sep 03, 2016 | Ryobi Garden
31cc 700r curved shaft string trimmer binding flywheel and cord rewind during reassembly
as you put it together, pull the handle a bit so the recoil starter fingers fit into the flywheel as they should
Aug 18, 2015 | Ryobi Garden
Need fuel line diagrm for ry60520 tiller
yes i would like to have one too. that way i could post it for you . but i don't sorry.
Jul 14, 2014 | Ryobi Cultivator
Cannot find the carb adjustment screws on my ryobi cultivator model ry60520
a lot of carburetors are being made with no adjustment screws available to the public for EPA reasons. if you can't find them then they are probably not there
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 19, 2013 | Garden
Starter cord has jammed
You will have to remove the starter rewind mechanism and rewind the cord around the pulley, then pre- load a certain amount of tension on the rewind spring.
Apr 17, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
My neighbor purchased a used RY60520 tiller, without manual. First, what kind of gas whe need to use, does it have to be mixed with oil? Starts, but running for a few minutes and stops. Blades are...
i really hope you didnt run that on plain gasoline. it is a two stroke engine and you can burn them up fast if you do so. heres a manual link for you...
https://usermanual.wiki/Ryobi/RyobiRy60520OwnerSManual.472987505.pdf
Feb 20, 2018 | Ryobi ZRRY46501 Factory-Reconditioned 12...
My 2 cycle ryobi tiller won't start. It has good spark but plug is dry. Fuel lines are good and primmer works. Any suggestions? Thanks
Try starter fluid in the chamber and see if it starts. If so, you may need to clean your carb.
Feb 23, 2010 | Ryobi Cultivator
Just tried starting my ryobi trimmer and the recoil spring on the starter rope will not rewind is their and easy fix?
Aug 23, 2009 | Garden
How to pretension starter cord on ryobi whipper snipper
Remove the housing and pull the cord partly out. Then rewind the rest. Check to see if it retracts properly. Good Luck!
Dec 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
