Question about Printek FormsPro 4503 Matrix Printer
How do I adjust the printhead gap on a Printel 4600?
Dot matrix printer head not properle work head jam problem
check
1- ribbon quality ( it might damaged )
2-Printhead gap - adjust the gap with the scaled arm aside the numbers related to the past thinketh ( no of copies)
3-ribbon mask ( metal plate in front of printhead - might be damaged)
Nov 06, 2014 | Epson LQ-2090 Matrix Printer
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
HP 4600 printer shows all cartridges OK and the print quality adjustment for all colors is set at 0. Have calibrated and adjusted color. Yellow does not print Pages come out in pinks
Try a new cartridge. If this doesn't solve the problem then check the lens cover of the yellow printhead. It should open when you close the front cover. You can check it by taking out all the cartridges and than close the frontcover slowly. Watch the lenscovers and check if they are opening when you close the front cover. Good luck, Gerrit Jan
Oct 29, 2009 | HP LaserJet 4600dn Color Printer
Problem with new installed printhead
If I remember the 320, there is a head-gap adjustment that is normally moved for replacement of the head and must be reset again. Check your manual for that term; 'Head gap adjustment'
Aug 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Fixed brains cant get my lexmark printer to work. lost dvd to install again!
You can find drivers and application for lexmark printers on producer website. Here is the link. You only have yo write there your printel model and download drivers.
Jul 13, 2009 | Computers & Internet
Light print out
Hi, before buying new bits, make sure that the position of the printhead is near to the paper, there will be a 'head gap adjustment lever. hope this helps
Feb 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Keeps saying "Auto Gap"
Does it Error auto gap, if so it means head gap is out of spec?
If it is just displaying Auto gap, it means it is set for auto gap rather that manual gap.
Jan 07, 2008 | OKI Pacemark 4410 Matrix Printer
Mp: bad gap home
Bad GAP HOME is a problem with the sensor (switch) that senses the automatically set printhead gap. Usually the wires break from flexing that run to the switch. Could be a bad switch also, or others.
You need to test the switch and wires with a meter.
Jan 03, 2008 | Printek FormsPro 4500 Matrix Printer
Printek FormsPro 4503 Matrix Printer Logo
108 people viewed this question
Top Printek Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Printek Office Equipment and Supply Expert? Answer questions, earn points and help others
