Question about Sta Rite Sta - Rite Dyna - Glas Pool Pump - 1 Hp
I have a 13 year old water feature pump (Sta-Rite 3/4 HP MPRA6D-146L) which has stopped pumping. I removed the motor/impeller assembly from the housing because I thought that I would find the impeller jammed with a pebble. But I found nothing. Then I briefly turned on the motor power to see if it spun --- but only heard a HMMMM. Is the Motor Shot?
    Top Expert:
  • Sta Rite Master
  • 4,292 Answers
Bad start capacitor or replace pump
Posted on May 19, 2016
3 Suggested Answers
  • 3 Answers
SOURCE: tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
Posted on Jun 04, 2009
john224
  • 1378 Answers
SOURCE: can't remove impeller to get pebbles out
What brand of pump? Most impellers are threaded on the shaft and you need to find a flat or slot somewhere along the shaft to hold it still while you spin off the impeller.
Posted on Jul 31, 2009
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a 1 hp Sta-Rite Centrifugal Pump, MPRA6#-147L. When on, water is coming it but the area with with filter is not filling up. I get no pressure on the filter and very little water is going to the...
CRACKED LID BAD LID O-RING,SUCTION LEAK, OR CLOGGED IMPELLER, LOOK AT YOUR BASKET IF IT HAS CRACKS, CHANCES ARE THE IMPELLER IS GOT **** IN IT. SPLIT THE PUMP AND CLEAN OUT THE IMPELLER , GET A NEW BASKET ASAP.. REMEMBER TO (PRIME THAT PUMP) AFTER ANY REPAIR !!!!
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jul 23, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I have a Sta-rite Max-E-Glas system in my pool. Every two to three weeks I have to dis assemble the pump section to remove small cedar fronds from between the impeller and the difuser. This is becoming...
Your local pool store sells a bag that goes inside the basket in the pump. This should stop everything(but the water) from getting in the impeller.
Jun 13, 2011 | Sta Rite Pool & Spa
Lost the prime on sta rite pool circulation pump
HI THERE , YA GOT THE BEST PUMP ! HAVE YOU HAD TRASH IN THE POOL ? THIS CAN MAKE ITS WAY TO THE PUMP AND PLUG THE IMPELLER , COULD BE SHAFT SEAL , THERE GOOD FOR 3-5 YEARS. UNLESS YOU HAVE STARVED THE PUMP FOR WATER,THIS KILLS A SHAFT SEAL.. TRY PRIMMING THE PUMP AGAIN. IF THAT NOT WORKING CHECK THIS LINK OUT IT WILL SHOW YOU PICTURES ON HOW TO REMOVE THE PUMP, SO YOU CAN LOOK AT THE IMPELLER .. IF I WAS OF HELP LEAVE ME A REVIEW.. GOT 2 BACK 2 FIX'N PUMPS.. GOOD LUCK..JAY .. http://maps.google.com/maps/place?cid=9186213048628859752&q=WHEN+SERVICE+CALLS+LONGWOOD+32750&hl=en&gl=us&ved=0CA4QtQU&sa=X&ei=ZLT2TMO3CangyQTS58z5Bg
Dec 02, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
My2 hp max e pro pump runs but barely moves any water
Have you opened up the wet end? If you have pine trees near you, it is probably a blocked impeller and needs to be cleaned. If this is not the case, is the pump basket full of water or air?
If it is full of water, it is either the impeller, or the motor bearing.
if it is full of air, it is an o-ring or shaft seal. more likely the shaft seal. Always check the impeller first.
Oct 09, 2010 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
1 HP StaRite Pump 15" inout Center Discharge 240V wHair Lint Pot: Impellers on pump wont turn. Motor not running...
what happens is the pump gets staved for water and this damages the shaft seal, water slowly over time leaks into the motor and pollutes the grease int the bearing and causes it to fail. it's fairly easy fix, just have the motor rebuilt by your local pool pump motor repair guy for about 75.00 and your back up and running. beats paying 200.00 or more for a new motor.
the sta rite is the top of the line pump, i have had them in my shop over 40 years old ! ask your motor repair guy how to get the most life out of your pump. knowledge is king .. remember to prime the pump after any pump repair !! .. jay longwood florida
May 17, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
Tring to take the pump face off the motor
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Sta Rite Sta - Rite Dyna - Glas Pool Pump - 1 Hp Logo
71 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
