Question about Bruder Mack Granite Flatbed Truck With Cat Bulldozer
2007 Mack granite. No brake lights. Turn and tail work. Low air lights work. Changed all the switches still nothing
I have a 2007 Ford Fairmont Ghia Sedan. Rear brake lights and indicators work but not the tail light.
tail lights work off the main light switch or through the light control module
the first click is tail and park lights , the second click is main beams or low beams
May 08, 2016 | Ford Cars & Trucks
WHAT DOES THE LIGHTNING BOLT WARNING LIGHT MEAN ON A 2006 MACK GRANITE
if you have cold weather its a tire pressure code that may take days to go away
Jul 15, 2014 | 2007 Dodge Caliber SXT Sport Hatchback
I have no break lights or turn signals
Turn signal tail lights and BRAKE LIGHTS NOT WORKING
It can be faulty brake light switch causing the problem or its blown brake light bulb. First check and confirm brake light lamp is working and that's not the case.
For turn signal not working it can be faulty turn signal switch or its issue with wiring:----
To trouble shoot brake and turn signal related problem, check the help links mentioned below:-----
Click the link:----
1996 Buick Regal Grand Sport Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work, but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
2003 Chevrolet S10 Tail light Fuse http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light Wiring diagram http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
Turn Signal Not working http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep Wagoneer? http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
1996 Chrysler LHS brake light circuit wiring diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake lights on 2004 Toyota RAV4? http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html 2007 KIA Rio: Brake Light Fuse Box Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
2004 Ford Mustang: Brake light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These will help.
Thanks.
Nov 24, 2012 | Cars & Trucks
My brake lights and rear blinkers are not working. I have replaced the bulbs in both brake lights. What next?
most blinkers uses relays, and when they flashes fast one light is out, but you replaced your burnt bulb might be a bad relay.
Sep 17, 2012 | 2007 Hummer H2 SUT
2007 chevy impala brake light and left turn signal not working
Fast flashing dash signals mean there is a bulb issue-DEFINATELY!
Aug 07, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
I have a 2007 Jeep patriot and the breaks lights will not work what should I do
Have you checked for 12 volts going to the brake light switch and have you pulled the complete brake/tail light assemblys out to ck for melted curcuit boards on the back side where the bulbs go in ? I not ... start with the Tail light cutcuit boards they melt all the time .
Aug 05, 2012 | 2007 Jeep Patriot Sport
The brake lights do not want to work. i have changed the brake switch under the dash and the bulbs on the tail lights.still nothing. i also, changed fuses.
does the high mounted brake light work? the brake switch has 2 contacts one for the high mount (LT BLUE/BLACK) and one for the tail brake lights. The tail/brake light wire is LIGHT BLUE. the main connector between the brake light switch and the tail lights is C208 which is located behind the rear seat, left side. So if there is power coming out of the brake switch OK and no power at the tail lights, check that connector. Hope this helps.
Sep 23, 2011 | 1989 Pontiac Firebird
2007 HHR Tail Lights won't work
my 2007 hhr tail lights don't work,brake lights and turn signals work.cant find a fuse for the rear taillights
Nov 07, 2009 | 2007 Chevrolet HHR Special Edition
My brake lights do not work but my tail lights and turn signals d
Check the fuse box and test the brake switch on the brake pedal.
Aug 07, 2009 | 2000 Dodge Durango
Bruder Mack Granite Flatbed Truck With Cat Bulldozer Logo
442 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
