Question about Canon ZR600 Mini DV Digital Camcorder
Him I have a Canon video recorder ZR600 and when I record and play the video it shows lines and squares all over theimage like pixels. Could you repair this camera?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on May 25, 2011
I was checking some recording and it looked good. Not long after that I put it on play again and now I have blue lines going through my recordings. Help! thanks in advance
Feb 13, 2011 | Canon ZR600 Mini DV Digital Camcorder
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
Image Sensor Problem
Does the black line record on the tape? When you play back on a TV/Computer can you still see the black line. If you do that would be the image sensor.
Good luck!!
Feb 13, 2009 | JVC GR-D850 Mini DV Camcorder
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Feb 11, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Pixels instea of clear picture
The problem is with the tape...Never rewind tape in the play mode for some reason it will screw it up.
And only use good tape such as...
Panasonic - MiniDV Digital Video Cassettes Model: AY-DVM80XJ
Dec 01, 2008 | Canon XL1S Mini DV Digital Camcorder
Low quality image from 2GB chip
Low resolution on memory card recording, regardless of the storage capacity of the card is just the way it is. If you consult the zr600 users manual (p. 82 of my edition - PUB.DIM-734/1205Ni15.1, c2006) you can find that video recording to the memory card is limited to resolutions of either 320 x 240 or 160 x 120 pixels. These resolutions are pretty poor - disappointingly so seeing that one of the old computer monitor standards used to be 640 x 480 and that 1024 x 768 is common today. I was disappointed too.
Mar 13, 2008 | Canon ZR600 Mini DV Digital Camcorder
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon ZR600 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
