Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Flashes il - Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Before calling service technician, open following link for Rheem tankless resources including error codes and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Read your manual for troubleshooting, advisories and required maintenance.
Tankless are maintenance heavy.
1L means tankless heat exchanger has lime build-up.
De-lime tankless unit.
U-tube has videos for de-liming tankless, but there is more to consider:
De-liming is yearly maintenance requirement.
Tankless are prone to lime build-up
Regular de-liming will not restore full efficiency to tankless unit.
Tankless cannot be exposed to water with more than 11 grains hardness.
Temperatures over 135 can cause minerals in water to harden on metal surfaces of any water heater.
Also clean Tankless water filter each month, and clean and maintain burner and combustion chamber yearly.
The cost of maintenance and cost of expected repairs and cost of parts plus cost of original installation will never pay back the $1-8 monthly savings on gas bill. All costs are energy.
Make sure there is qualified service technician in area before buying tankless.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 24, 2011
I have a Richmond tankless water heater and it has L1 error code...can somebody help me with this?
Might be able to help. Except L1 does not show on any error code file.
Copy following link for Rheem Richmond Ecosense etc computer water heater troubleshoot resources
Are you sure the error is not IL? Delime tankless.
Or UL flashes and indicates reset.
Or CL flashes and indicates fault history is cleared.
Or error 11 combustion failure? Call for service.
Or P1? Low water pressure, clean water filter check for leaks and crossover caused by bad single-handled faucet cartridge.
I recommend calling Rheem to find local technician who is qualified to work on tankless computers. Tankless are not ordinary water heaters, and they require continual maintenance to avoid common error codes, especially as unit gets 2-3 years old, after warranty has expired.
The required maintenance and expense of repairs, and general fact that people cannot make their own repairs, make tankless computers a bad choice for heating water.
If unit is 4-5 years old, it might be best to install tank-type heater for $385 from Lowes and cut losses.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 08, 2013 | Rheem Richmond Encore Tankless Nat Gas...
My control unit keeps alternating between 120 and IL. Cannot find code IL
Before calling service technican, copy following links for general troubleshoot resources and error codes, and manusls, and Rheem contact information:
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Error IL usually means delime the unit.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Read your product manual for yearly/monthly maintenance schedule.
Tankless are maintenance heavy and must be delimed each year.
Deliming using white vinegar take about 1 hour, and will not restore full efficiency to unit.
Tankless have the habit of forming lime deposits inside the heat exchanger, even with softened water.
Tankless cannot be exposed to more than 11 grains hardness in water.
Don't buy a tankless next time.
Read the manual first.
Aug 09, 2012 | Rheem Rtg53xn Natural Gas Tankless Water...
My rheem was flashing IL . I flushed with 2 gallons of vinegar for 45 minutes. however when I restarted it still is flashing IL. Does something in the remote need to be reset?
Before calling service technician, open following link for Rheem tankless troubleshoot resources, including on-line chat
Rheem technical service bulletin for de-liming:
De-liming Manual says:
10. Turn on the water shutoff valves, run a hot water tap to
purge any air from the water lines and check the system
for any leaks.
11. Turn on gas, electricity, and remote control thermostat
and set the desired temperature.
12. Run hot water from several locations to check the operation
and performance of the water heater.
If you have difficulties please contact the Technical Service
Department at 1-800-432-8373 or your local service agent.
Apr 18, 2011 | Rheem Tankless Water Heater Main Remote...
I am getting a IL code on my display
IL code is: water heater has lime deposits.
Tankless should be de-limed each year using white vinegar..
Search U-tube for "de-lime tankless heater" to see how to do this yourself, or call service technician.
There are special fittings that can be added to tank at the hot-n-cold ports that let you easily de-lime your water heater each year.
Typical manual shows error IL on page 33:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Typical manual also shows regular maintenance on page 29.
The word maintenance is used throughout the manual.
Research shows that regular de-liming will not restore full efficiency to tankless water heaters:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
Feb 15, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
May 16, 2010 | Rheem Tankless Hot Water Heater...
My rheem umc-117 controller flashes an IL code.
it means that you have lime build up in the heat exchanger and it needs to be flushed out ASAP!!
Jun 27, 2009 | Rheem Tankless Water Heater Main Remote...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
242 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
