Question about Hightech HIS H695F2G2M RADEON HD 6950 2GB 256-bit GDDR5 PCI Express 2 1 x16 HDCP Ready CrossFireX Support Vid Video Card
My computer lets off a constant high pitched beep when I turn it on - and the monitor doesn't display anything
  • Alex Edoh
    Alex Edoh May 24, 2011
    These can be caused by one of two major thing. I can only determine which it is if you can answer this question. Is the beep coming fast or having a short regular interval.
  • 390 Answers
there are generally two reasons for the high pitched beep either a faulty RAM or an faulty Video card first try to remove the ram clean the contact areas and replace it if the problem still persists then do the same with the video card, if the thing is still nagging then replace either of the components one after the other to check which has a problem
hope this helps
Posted on May 24, 2011
High pitched noise/beep on emachine e440 laptop
In Windows 7 ,Try the Power Options in Control Panel. Set to High Performance, select Change Plan settings, set Sleep to never, select Advanced Power settings, scroll through the Advanced Power settings, set Sleep and Hibernate to Never and Power Buttons and Lid to Shut down. Always shut down and unplug the Laptop when not in use to prevent damage due to a power surge and a possible Fire hazard IF the battery malfunctions. Not to mention unnecessary wear on the components.
Apr 16, 2013 | eMachines Computers & Internet
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
RCA ctc195 series won't power on constant small beeping sound
if its a high pitched squeek its a short in the deflection circuit, a common failure part here was the high voltage transformer.
Dec 11, 2012 | Televison & Video
Computer beeps every 30 seconds
It is car brakes. Turn that game off.
OH, I'M JUST KIDDING!
BIOS speaker is broken, and you hear high pitched beeps?
Hmmmmm,..........
CPU temperature in normal............
What is the CPU, and what is the temp? Hey, I gotta know so we are on the same page here, lol!
Me?
Those repeated high pitch BIOS Beep Codes indicate a CPU problem.
I would remove the Heatsink/Fan combo, and replace the Thermal Paste.
(Following Anti-Static Precautions, and cleaning the CPU, and Heatsink, of course)
Also make sure the Heatsink is sitting flat.
Yes, I know what you stated about Speecy, and Core Temp, but I would try it anyway.
Still no?
CPU is sounding Taps, and telling you goodbye.
Regards,
joecoolvette
Jul 29, 2012 | ASUS Computers & Internet
Acer aspire x1700 black screen, makes high pitched noise, doesn't respond
You may have damaged or dislodge a component.
I suggest you remove the cover and reseat the RAM modules and all the cards in the expansion slot (unscrew them pull them out of the expansion slots and insert them back then secure them with the screws.
If it still does not boot up then you need to take the computer to a computer repair shop.
Mar 11, 2012 | Acer Computers & Internet
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
My CPU is on but no display in the monitor.
may be your video card is broken.. try to barrow a monitor from your friend or relatives and test if the problem is in your monitor or video card..
Apr 18, 2011 | Computers & Internet
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Hightech HIS H695F2G2M RADEON HD 6950 2GB 256-bit GDDR5 PCI Express 2 1 x16 HDCP Ready CrossFireX Support Vid Video Card Logo
127 people viewed this question
Top Hightech Computers & Internet Experts
David Payne
David Payne
Are you a Hightech Computer and Internet Expert? Answer questions, earn points and help others
