Question about Princeton Digital VL1916 19" LCD Monitor
VL1919 blue light flashes continuously, monitor does not turn on. . . even after DAYS of flashing. : (
  • 1,056 Answers
That is the problem with the standby section of the power supply. A continuous flashing indicate a shorted component usually a small diode.
Posted on May 24, 2011
Screen isn't coming on. I have a Princeton VL1919. The blue light blinks when on and the screen is just black. I have tried it on all 3 of my computers and it won't work. Any help would be awsome. Thanks
Common failure on the Princeton monitors are caps failure in the power supply, look for bad caps (bulging top or seal), see failed Princeton monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 26, 2010 | Princeton Digital VL1919 19" Monitor
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
Screen remains black and flashing blue light on power button
I also have the exact same problem. My monitors been collecting dust for a while now and I can't find the solution anywhere.
Aug 05, 2008 | HP f1905 19" Flat Panel LCD Monitor
Monitor dark for 20 minutes before turning on
My VL1919 has been having this issue off and on for a month or so now. It happened three times in one day today, so I decided to do something about it. I opened up the monitor and poked around a bit.
I found three electrolytic capacitors on the backlight inverter board were bulging, two of which had just started to leak: 71706a0.jpg The capacitors were placed directly above and next to a large, flat metal heat sink. I say above with respect to the flow of air due to convection, and next to because the heat sink also wraps around, enclosing the group of capacitors on one side. The heat sink sits flush with the circuit board, turning the board into a front enclosing face. When reassembled, the metal housing sits a fraction of an inch above the sink, forming a back face. This assembly is at the top edge of the circuit board, so the housing then takes a 90° bend to form a top face. These capacitors seem to get almost no air flow... Together with the heat coming off the sink, it appears the engineers have created their own little capacitor oven. Capacitors immediately adjacent to the affected components, but without blocked air flow looked completely normal. Looking at the traces on the circuit board and location of other components, the capacitors could have easily been moved out of the hot spot. This is either an act of gross negligence, or an intentionally created post-warranty failure point, designed to avoid market saturation. But that might be too pessimistic... "Never attribute to malice what can be adequately explained by incompetence." Anyway, I scavenged a few capacitors off an old computer power supply to replace the damaged parts (one 470uF 25V two 1000uF 10V capacitor, both rated to 105°C). To avoid a repeat performance, I soldered some short extension wires to the replacement caps and moved them out to an open area of the board, being careful to give the high voltage components plenty of breathing room. After reassembly, the monitor powered right up and came online. I guess the real question is how long it will stay this way.
Apr 05, 2008 | Princeton Digital VL1916 19" LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Princeton Digital VL1916 19" LCD Monitor Logo
358 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
