Question about GCC Technologies Elite XL 40N Laser Printer
Hi, we have a GCC Elite XL 40N Printer at work on a network with about 12 computers attached to it. One day when I wasn't here, (so im not sure how it started) It started printing A LOT of sheets with random symbols on it. How do we make this stop? We've tried shutting it down, pressing cancel job over and over. I've reset it to default, AND cleared the print que on all the computers including the server computer. Its currently off, any help is appreciated.
    Scholar:
  • 61 Answers
This could be caused by a few different problems with the printer but here are some troubleshooting techniques that may help:
1. Check that the printer is able to print correctly on its own. Print out a configuration page from the printer or install the printer onto a new machine as a local printer and print out a test page. If this prints out as symbols, the problem is a most likely hardware error and the printer will need to be serviced. Try step 2 before servicing. If the printer prints normal characters, go to step 3.
2. Carefully go through the settings on the printer and review the printer's configuration page to make sure everything has the correct settings and nothing was changed accidentally.
3. The most common problem is that the drivers on the print server, or on the server computer, have become corrupted. In Printers and Faxes on the print server, delete all the drivers for the printer, reinstall them, and then add the printer again. Make sure to print a test page at the end of the add printer wizard.
4. It could be a problem with the ethernet cable so try swapping the current ethernet cable with a new one.
5. If it is still printing symbols at this point, it is most likely a hardware issue and the printer will need to be serviced.
Posted on May 24, 2011
Hi, I can't use the printey GCC Elite, XL 20/600, after I have installed system Mac OS X 10.6.6 I can't see the printer now. I tried to use drive from the GCC site, but It was nuless. What I can...
you should connect using ethernet. (probably no other way at this point, unless you found some crazy adapter, i guess)
click the apple logo in the upper left corner.
select system preferences:
select network:
select ethernet:
you have two choices, you can either write down the computers IP address and use that in the printer. or you can manually set your own here by choosing "Use DHCP with manual address"
if you already have a bunch of stuff networked, you probably shouldn't change your IP. but if the current IP isnt one you can set your printer to, then you'll have to change it here.
lets say your computer IP is set to 192.000.001.001
in printer your printer menu:
go to interfaces:
go to tcp/ip (make sure it's enabled): ip class C, subnet mask FFFO, go to IP address
set to 192.000.001.002 (it needs to be almost the same as the computer, but with the last number different)
in preferences: printers: add printer:
Protocol: LPD
Address: 192.000.001.002:515
[THE 515 AT THE END IS THE PORT NUMBER, ITS SUPER IMPORTANT]
Queue: EliteXL [ALSO IMPORTANT]
Name: gcc (doesn't matter)
Print using GCC Elite XL 20/600 v3.31 (or whatever driver you have)
hints if those numbers didnt work for you:
I got the queue number and port number by printing the config page directly from the printer (not the help page)
On the config page, look for "interfaces"
under that, look for "TCP/IP"
under that, look for "Lpd"
there you will find the queue name and port number. this info was missing from a lot of the other online solutions i found and it didnt work until i got it right. (use the port number listed above the queue name, not the one listed below after TCP)
Feb 21, 2011 | GCC Technologies Elite XL 20/600 Laser...
I run windows 7 64 bit i need a driver for a ccc elite xl 608 laserprinter
If you have a Windows XP x64 CD, try the GCC SelectPress 600 or Select Press 1200 driver. The SelectPress 1200 worked for my Elite XL 20/1200. I believe the only 64-bit drivers that are available for GCC printers are on the XP 64 disc.
Dec 09, 2010 | GCC Technologies Elite XL 20/600 Laser...
Printer software
Look first at the Microsoft Compatability list (search same for link) for your device. If listed, they will have instructions for you there. If not listed, you will have to beg GCC for a driver. You might find a 3rd party driver ...
Alternatively, if you have another computer, (XP or Vista based) connect your printer to that computer and use it as a print server on your network.
Thanks for your interest in FixYa.com
a
Dec 26, 2009 | GCC Technologies Elite 12/600 Laser...
Gcc 20/1200 driver windows 7 64 bit
If you have a Windows XP x64 CD, you can use the GCC SelectPress 1200 driver. This works perfectly with the XL 20 1200 with all features and paper sizes.
Nov 29, 2009 | GCC Technologies Elite XL 20/600 Laser...
Elite 20/600 not working with Snow Leopard
Snow Leopard broke Appletalk which is how many people connected a GCC printer to their Macs. You must reconfigure to LPD in the print and fax control panel and everything works fine. If you have difficulties please email jstrauss@gccprinters.com as we do not have this posted to the Web yet.
Aug 31, 2009 | GCC Technologies Elite XL 20/600 Laser...
GCC 12/600 Not found under Leopard (on wireless network)
Same problem.
Plus I am trying to find a legitimate download for a 12/600 printer driver that will let me print from my new MacBook Pro running Jaguar.
Peter B.
Jan 07, 2008 | GCC Technologies Elite 12/600 Laser...
GCC Technologies Elite XL 40N Laser Printer Logo
218 people viewed this question
Top GCC Technologies Office Equipment & Supplies Experts
k24674
Are you a GCC Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
