Question about Kenmore Washing Machines
Our washer is not filling with enough water. We set it for a large load and the water level is that of a medium or maybe even less.
  • Kenmore Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on May 24, 2011
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
WHY IS WATER LEVEL LOW CAN I CHANGE THE SETTING ON WATER
there should be a knob on the control panel showing small, medium, large maybe even super. that is how you change the water level. Its for different amounts of clothing your washing at a time. If you put in a few clothes then you have the option of using less water.
Jul 31, 2014 | GE WBSR3140DW Top Load Washer
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
Apr 17, 2011 | Washing Machines
Water will only fill up half way when set for a large load and very little water when it's set at medium load.
put less of a load in to compensate the amount of water and save wear and tear on your washer :-)
Jun 22, 2009 | Westinghouse Washing Machines
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Washing Machines Logo
216 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
