Question about Acard Technology (ARS-2030LD) DVD±RW Burner
Target drive not ready - Acard Technology (ARS-2030LD) DVD±RW Burner
  • Acard Techno... Master
  • 27,725 Answers
You might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 24, 2011
The burning drives are not recognizing the blank media.Try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.Try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.Finally clean the drive bays by using compressed air to blow any dust out of the system.
Dec 18, 2013 | ProDuplicator Computers & Internet
Yes my EZ Dupe has been working fine all of a sudden it says Target Drive Not ready. What do i need to do Thanks
Try a different target drive, the target drive may be defective.
If not, the EZ Dupe may be defective.
Make sure the target drive spins up...if it doesn't, it's defective, or there is a power problem.
Jun 18, 2011 | Computers & Internet
The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Jan 09, 2011 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
My ACARD Technology Pro DVD duplicator is giving me a "Target Drive Not Ready" message and will not duplicate. What can I do?
My ACARD Technologyicon1.png Pro CD/DVD duplicator is giving me a "Target Drive Not Ready" message and will not duplicate. What can I do?
Nov 30, 2010 | Computers & Internet
When I put the disc in to be copies and then the blank discs i press the green start button and it display target drive not ready. How do I get it to copy onto the other discs??
One of the "target" CD-writers is not working -- either the "data" cable is not connected, or the "power" cable is not connected, or the drive itself (either the "spinning" motor, or the "laser") has failed.
Presumably, you don't have to fill "all" the trays, in case you only want to make a few copies of the "source" disk.
So, make a few attempts, with the "source" disk in the "source" drive:
1. put a blank disk into the 1st "target" drive,
leaving the other targets "empty", and press the button.
If it works, then the 1st target drive is OK.
2. put blank disks into the 1st and 2nd "target" drives,
If it works, then the 1st and the 2nd target drives are OK.
3. put blank disks into the 1st and 2nd and 3rd "target" drives,
If it works, then the 1st and the 2nd and 3rd target drives are OK.
... and so on
If you get a "failure", then you now know which of the "target" drives is the "bad" drive. Either replace that bad drive, or change the cabling inside the unit to "bypass" that bad drive, and put a sticky-label on the face-plate of that drive, saying "do not use this tray".
Oct 16, 2010 | MicroBoards Quick Disc QD-123 (QD-123)...
What do you when it says target disck is not ready on a duplicator
Your disk *WITH* the data is the "source" disk.
Your "blank" disk is the "target" media.
Try a different "blank" disk.
If not any better, then take the unit to a computer technician, to trouble-shoot the hardware that is used to write onto the "target" media.
Apr 02, 2010 | EZ Dupe 1-Target CD/DVD Duplicator with...
Target drive keeps saying not ready
May I suggerst you reseat all internal connections on your drive? (Power, IDE or what ever) Make sure you are grounded to the case while you do this and you have the power cord disconencted from the wall.
Close up everything and re-connect all the stuff you disconencted.
After you do that, remove the device via the device manager.
Reboot - let windows refind the device. Have the driver CD ready if applicable.
Let me know what happens.
a
Sep 21, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Acard 1 to 3 duplicator can't seemto get past the traget disc not ready
of course theres a problem but what are you doing with the thing? are you formaating the disk first to render the dvds in the target drives? are you using the right DVD like DVD+ DVD+- or Blueray? need more information to help you. and it the DVD you are copying has been redered on another machine it won't copy it anyway. You have to use the same machine to copy it as thats how they protect copy rights now days.
May 29, 2009 | Computers & Internet
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
117 people viewed this question
Top Acard Technology Computers & Internet Experts
David Payne
David Payne
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
