Question about GE Dishwashers
I live in the ny area. I own a ge pdw9700lii dishwasher with a costly custom wood front. This dishwasher has a top rack that has been a major problem for 5 yrs. The track has broken over 15 times. PC Richards has given me a $1100.00 credit to buy a new dishwasher from them. This washer is discontinued. The only unit GE makes is the pdwt502rii that accepts a custom wood front.GE says my panel will probably not fit. He wasn't 100% sure. Can you tell me if I can use my custom panel. I can't have another made.
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Posted on Nov 30, 2008
  • 10865 Answers
SOURCE: GE dsd 6700 top rack glider wheels not turning,
remove the tray and look at the wheels to be sure they are completely attached to the tray itself. If they are spray them with PAM or another cooking spray product to lubricate them.
Posted on May 18, 2009
woobie dog
  • 1273 Answers
SOURCE: How to summarize GE Monogram - JUNK
Brother, I feel your pain, truely. I have the 'Profile' models.....same as your's, with less trim. You can buy all of your parts for much less. Type in ' GE (your number here) dishwasher repair' into a google search, and you can find a number of sources of parts and diagrams and manuals, (oh my!) Anyway, I go to apliancerepair.com a lot. I've actually had pretty good luck with my appliances. GE makes a pretty reliable appliance statistically, and parts are readily available from a variety of sources. Be thankful that you didn't buy one of the wierd off brands or a Fysher Pakyl. I see regular posts on bizarre things for them.... You really bought the best choice in my humble opinion. A lot of the time, the problem is just something loose, or stuck. Pull your timer, and check to see if you can see anything loose, or stuck, or out of the ordinary. You can't break it....it's already broke! That's my attitude. I;ll give it one more shot before I call it dead. But I digress.... Parts on line will vary wildly in cost, so I recommend that you do your homework before throwing down the change.
Best regards, --W/D-- you can rate this solution if you like! thanx!
Posted on Aug 07, 2009
SOURCE: My GE PDW7880G doesn't clean items in the top
removed the sprayer. the part that spins under the top rack and check that the holes arent clogged.
Posted on Feb 23, 2010
SOURCE: Need replacement rack.
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=HOMEPAGE
Posted on Aug 06, 2010
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
I live in Queens NY and i would like to know where i can take my Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg for serviceing. Having a problem with the conection area where the main lead...
hi,
Have added the address of GE medical systems in NewYork. Call them, they will lead you to the servicing center
ok
1. 47 Greenwood Lane, Valhalla, NY 10595-1110, United States +1 914-946-5470
2. 11 Fairway Drive, Old Bethpage, NY, United States +1 516-753-1266
Aug 07, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
May 18, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishes in top rack not getting clean
If you live in an area with 'hard' water (having more than 5 ppm) you may require a whole-house treatment system to eliminate the mineral content that will wreak havoc with any water-related system (including your water heater).
If that is not the case I would have a service call to check the upper level service arm, which must be pushed in to a hole in the back of most units in order to get the water to flow in.
Oct 01, 2017 | GE 24 in. Profile PDW9880JSS Built-in...
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Nov 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
