Question about Black & Decker 19" Electric Lawnhog Mulching Mower
Can you tell me how to open up the switch/lever housing on the B & D electric mower? The orange handle came off in my hand and I want to open it up to see if something is broken or if it may just have slipped off something or other. Thanks very much
  • edsmarion May 24, 2011
    Here's the parts diagram. Not much help. It does appear as if there are multiple screws/nuts in addition to one large Phillips-head screw. I can't for the life of me figure out what kind of tool I need to unscrew these other screws. http://www.ereplacementparts.com/images/...
    Thanks very much!
  • 19,396 Answers
Hi.
It depends on the model. The housing is usually held by screw. In the following link you find exploded views showing the position of the screws for each model. Please click here and select your model to get the full exploded view.
Regards.
Ginko
Posted on May 24, 2011
  • Ginko
    Ginko May 24, 2011
    Hi.
    You need a security screwdriver, which is a tool that is supposed to be provided only to authorized technicians.
    Buy a security set with all tips for less than $15, that will do the job and it is a tool that every DIY person must have. Here a complete set: Grip on Tools 62100 - 100 PC Security Screwdriver Bit Set.
  • Ginko
    Ginko May 24, 2011
    You are welcome.
    All the best.
    Ginko
The bulb in my left headlight is burned out. How do I change it?
FIRST OF ALL YOU HAVE HALOGEN BULBS YOU NEED TO WEAR CLEAN DRY GLOVES ON HANDS WHEN HANDLING HALOGEN BULBS.OIL FROM HANDS WILL CAUSE THEM TO BURN OUT.OKAY TO REPLACE HEAD LIGHT BULB.OPEN HOOD AND PULL UP THE RELEASE LEVER AT THE BACK OF THE HEADLIGHT HOUSING.THE HEADLIGHT HOUSING SLIDES IN AND OUT OF THE BODY IN TRACKS.PULL THE HEADLIGHT HOUSING FAR ENOUGH FORWARD TO DISCONNECT THE ELECTRICAL CONNECTORS THEN SLIDE THE HEADLIGHT HOUSING AT THE WAY OUT.TO INSTALL THE HOUSING SLIDE IT BACK IN ALIGNING THE RIDGES ON EACH SIDE WITH THE TWO TRACKS IN THE BODY.WHEN THE HOUSING IS IN FAR ENOUGH REACH THROUGH FROM THE INSIDE THE ENGINE COMPARTMENT TO REATTACH THE ELECTRICAL CONNECTORS.
Aug 19, 2010 | 2000 Volkswagen Beetle
Black and Decker Electric mower #M2370 lever
you could just try drilling the case out where the lever pivots and put a long nut and bolt to hold the lever in place
Mar 31, 2010 | Black & Decker Garden
The on/off switch (handle) does not work. How can I get it fixed?
As many others have noted, the orange switch lever pivots on a plastic pin which breaks off within two years of normal use. I found a 3/16" steel rod at my local home center in the same bin where threaded rod and angle iron are kept. I'm sure brass or alumium rod would work as well. I cut off a 1.7" length of the rod using a hacksaw and deburred the end by rubbing it on a flat file.
Before working on the mower, take off the cover, disconnect one battery lead, and secure it so it can't reach the battery terminal. You don't want the mower to start up while you are working on it.
Now diassemble the switch housing. On the part of the housing where the switch is located, find where the original plastic pin broke off. If the pin didn't break off cleanly, trim it flush with a file or sharp knife, then drill a 3/16" hole to a depth of 0.45". Be careful to center the hole. I started with a small pilot bit, then enlarged the hole to 3/16". Put some tape on your bit to keep from going too deep. The plastic drills easily.
The rest is easy. Insert your replacement metal pin, reassemble everything, and test. Give the rest of the rod to a friend who owns the same mower.
Mar 27, 2010 | Black & Decker 19" Electric Lawnhog...
Have a black and decker 19in electric mower. was
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 23, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker MM850 switch and arm pivot failure
Sep 15, 2009 | Black & Decker 19" Electric Lawnhog...
Electric lawn mower mm850 wont start, trips breaker.
I have repaired mines.  It was found in the trash dump, just before street curb side trash collection.  It is a very sophisticated lawn mower.  It taken me a month to restore it.  The problem is the housing is poor design and does not hold the pin switch securely.  This is not a simple on/off switch.  It is switch module with two momentary switches built in to it to work simultaneously.  The hot is a normally open momentary switch and the neutral is a normally closed  momentary switch.  Two things must occurred simultaneously for the lawn mower to work.  The AC hot has to close and the neutral to open.  This is a split phase AC motor.  The switch has four connectors to it.  The first two has black wires to it, for the hot, that is normally open.  The second two has a white wire and red wire to it for the motor's start up winding.  The orange connects with the plug's white, neutral.  A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close.  It will take two fingers to operate the lawn mower.  I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing.  Often, there is nothing wrong with the switch.  I tested mines and it works fine.  The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate.  I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out.  Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower.  I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Jul 10, 2009 | Black & Decker 19" Electric Lawnhog...
Electric lawnmower handle is hard press which starts the lawnmover
switch problem also checked the pin housing that holds the orange lever if not worn out. if is worn replaced both.
Jun 17, 2008 | Black & Decker 19" Electric Lawnhog...
B & D flip handle electric corded mower
do you mean the orange lever came off. if thats the case you need the switch housing assy & a spring. the lever was held by the plastic housing pin or pig. some times the plastic pin worn out before it breaks.
Jun 13, 2008 | Black & Decker 19" Electric Lawnhog...
Black and Decker Electric Lawn Mower MM850 wiring diagram
"Split Phase Motors
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
246 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
