Question about Konica Minolta DiALTA Di183F Copier
Minolta di 740 error code c 143e - Konica Minolta DiALTA Di183F Copier
  • 106 Answers
What is the truth c14a3 or c143e?
Posted on Jun 13, 2011
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
MY PROBLEM IS THIS ERROR CODE C 143E THIS MECHIEN IS MINOLTA DI 550
If you cannot find error code definitions in the supplied software, you should go to support, on the Minolta website. There select your model # and in troubleshooting you should find the codes.
murf427
Aug 01, 2012 | Minolta Office Equipment & Supplies
Having c-143e when connecting adf to di 620. When i remove adf socket and restart the error goes away and machine works fine
Sir, It is the document feeder, the Di620 is a very old MINOLTA machine, but you mite find a (NOW) Konica Minolta dealership that can update the document feeder EPROM (Erasable Program able Read Only Memory) chip located on the document feeder control board. It has to have its program updated to correct this problem which gives this code. Let them know you have the Technical Bulletin # 2617b they will not be able to call it up but mite be able to contact some one at Konica Minolta tech support that can get access to very old MINOLTA technical bulletins. Additional info is Knowledge Base # TAUS0645133EN00. Then will have to hope that Konica Minolta has keep the Firmware for the chip????? Maybe in JAPAN!!!!!!!!!. YOUR ASKING ALOT TO GET THIS MACHINE TO RUN!!!!
Mar 30, 2012 | Minolta Office Equipment & Supplies
Minolta copier di-450 code : c-143e
The correct error code is C 143E - EDH malfunctions.Please reset the malfunctuion code to open and closed the front door,or turn OFF wait 5 sec. and turn ON the power switch.If the problem persist change the image processing board.
Pick up motor malfunction
Whwn the document handling tray goes to up the pick up raised position sensor is not unblocked when the motor started turning forward.Whwn thw DHT goes down the pick up lower position sensor is not unblocked after the motors started turning backward.
During ascent motion check :
1.Foreign matter on pick up motor gear
2.Pick up motor operatio.The voltage across PJ11A 1 of main control board and GND is 0V when the motor is deenergized and 24 V when the motor is energized when the DHT is raised after the malfunction reset.
3.Pick up raised position sensor operation.
Change the motor,sensor or main control board.
During descent motion
1.Check the pick up motor gear.
2.Check the pick up motor operation
3Check the pick up lower position sensor operation.
Aug 28, 2009 | Minolta Office Equipment & Supplies
Minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Jun 09, 2009 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di183F Copier Logo
547 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
