Question about Lexmark Z2300 InkJet Printer
My lexmark Z2300 will not feed the paper. The roller in the back (by the paper) does not move. I just changed the black ink. It has also said communication problem when I tried to print. NOW when you turn it on, it automatically tries to feed a piece of paper in, isn't able to, and then the light blinks.
  • Official Brand Answer
  • 3,344 Answers
Disconnect the printer from your pc. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check the cartridge area and make sure there are no obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip) behind the carrier. If everything looks fine, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Close the cover. Reconnect printer to the computer. Try to print again.
Posted on Jun 02, 2011
Lexmark 2500 not feeding paper
I am have the same problem and I just bought New Ink. does anyone know what printers are compatible with Lexmark ink.
Feb 01, 2013 | Lexmark X2500 All-In-One Printer
When i hit print the printer does not take the paper, the roller goes around but the paper is not feeding through
This is due to a build up of paper residue on the pickup roller. If you look in the back of the printer where the paper is inserted there will be a soft grey or black roller, this requires cleaning with a lint free cloth soaked in a chemical based cleaner such as isopropyl to bring the 'grippiness' of the roller back. At the moment the paper dust is making the roller slip rather than grip.
Mar 01, 2010 | Lexmark Z2300 InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z715 problem w/printing
Good luck...
Nov 10, 2008 | Lexmark Z715 InkJet Printer
I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without...
Oct 20, 2008 | Lexmark Office Equipment & Supplies
Paper not feeding
Aug 26, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X4850 paper jam
May 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Z2300 InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
