Question about KitchenAid KERC507 Electric Kitchen Range
Oven door lock
When starting self clean cycle the oven door lock repeatedly tries to engage
    New Friend:
I had the same problem. Apparently this is a common problem. Repair guy wanted $300 to fix until he found out he couldn't order the parts. It turns out that it is just the tab on the limit switch which has worn and no longer engages the switch (so the solenoid thinks it hasn't engaged the lock and keeps trying). Try the following:
(refer to parts manual at https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208187579.pdf)
1. Unplug the range
2. Remove the rear panel (see Rear Chassis drawing)
3. Locate the oven lock solenoid #6 (part #9752404) near the top
4. Move the rod assembly by hand and use a non-flammable lubricant (silcone, graphite) to lube the rod and metal parts that slide.
5. Bend the metal flange on limit switch 12 down as much as you can (rod will be in the way. This is your main problem: the flange has worn or bent and no longer rises high enough to engage the limit switch.
6. Replace panel, plug in and try it again.
If that doesn't work you may have to try disassembling the whole assembly so you can manually bend the flange down. If that still doesn't work search the internet for Whirlpool 9752404. I found a couple of sources that still had the part for sale.
Posted on Apr 20, 2012
  • 594 Answers
When in the cleaning mode the door lock will engage to make sure the heat does not get out. if it will not engage make sure there is nothing blocking the lock.
Posted on Aug 15, 2008
SOURCE:
My Viking electric oven will not self clean, any suggestions.
Ensure the door is closed securely if the Viking oven will not enter the self-clean cycle. If the door is not closed completely, the door lock cannot engage to start the self-cleaning.
https://www.hunker.com/13408313/how-to-troubleshoot-a-viking-oven
Jul 26, 2018 | Viking Ovens
I can't get my GE range to self clean, I keep getting a F91 error whenever I try to clean.
Unfortunately, the F91 error indicates that the door lock is not functioning or the signal that the door is locked didn't get to the control unit. The range will not begin the self-clean cycle if there is a chance that you could open the oven door when the oven is dangerously hot.
First try cycling the power by unplugging the range (or turning off the circuit breaker). Next check if the lock has engaged. If the lock doesn't engage, check if the mechanism is bent or binding. Next check the wiring to see there is damage that will prevent the communication between the control board or the door lock. Check for corrosion at the wiring harness connections.
If the error happened after doing a self-clean, I'd suspect the door lock hadn't released. That can be related to a damaged over-temperature sensor or the lock itself. If the range has been self-cleaned before, it's possible that the lock was broken after forcing the door to open after that self-clean cycle.
You may need to replace the lock, the wiring or the control board. Please add a comment with the model of your range for a parts diagram. If your range is under warranty, contact GE.
I hope this helps.
Jun 26, 2018 | GE Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
How do I unlock the oven door?
If the lock is engaged, is the oven in a self cleaning cycle? If so, cycle power to the oven, that should cancel the self cleaning cycle.
Reply back if that worked or not and I'll try to help you further.
Jan 24, 2009 | Frigidaire FEF352 Electric Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
172 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
